    Sketchup 8 experience problem
    7 Posts 3 Posters 480 Views 3 Watching
      kken
      hello guys, need some help here. my sketchup has been acting weird when i attempt to open a new sketchup file with sketchup 8. I tried opening just a plain file as well but it turned out the same way. The problem is that the sketchup program only shows the top and bottom menu but nothing in between except for my previously open windows. Here is a screen shot of what I am trying to describe:
      http://y6i92a.bay.livefilestore.com/y1pIKLKzOKo6YLAqYPgqyjg4kE4R0-cdPhWQ6KTc388ysCXMuQinlGH4l9tC2ZdNE5AtJOzvGovYQuNoJjYsvSaujIeyRkTvSZ5/Capture.PNG?psid=1
      Please advise how can i fix this as it's a little urgent for me to finish up some works at the moment, thank you!
      • mitcorbM Offline
        mitcorb
        Did you somehow install SU8 in the wrong folder? Perhaps in SU7 folder?
        Why the OS is not allowing a complete start is beyond me, unless you scrambled the registry or something?
        Sorry, I have never seen this before.
          My money is on a graphic card issue.
          If you disabled Hardware Acceleration in SU, do you get the viewport then?
          If so - then it is a graphic card issue and you should update your drivers.
          Btw, what graphic card do you got?
          • mitcorbM Offline
            mitcorb
            I responded only to keep this thread afloat, as I am not qualified or experienced in the hardware/software/operating system interoperational jungle.
            I was really hoping someone could see this and help.
              My suggestion was no good?
              • mitcorbM Offline
                mitcorb
                @ThomThom:
                Kken hasn't responded, yet.
                And I was not casting aspersions on your suggestion- which may be the answer to his question.
                I have noticed that aside from you and a couple of others, there are very few troubleshooters in this specific area of interoperability.
                  Unusually the first thing to test is the graphic card - as it's the cause in 90% + of the cases.
