    DC "Flipping" Script
    19 Posts 2 Posters 2.0k Views 2 Watching
      hmm.. are we talking about just flipping, or adjusting axis completely?
      Is it swapping X for Y or Z etc?
      • E Offline
        ericschimel
        Lets say you took the above DC and rotate the axis about the Blue axis. In other words, you switched the direction of the green and red axis, leaving the blue one in the same direction. For the DC not to "Blow up" you'd need to switch every Red axis formula with Green axis references and vica versa, leaving the blue ones alone.
        Doing this manually is really tedious and dangerous, even on a simple DC such as this one.
        -Eric
        http://plugin.sketchthis.net
        Sketchup Kitchen Design Plugin
        Custom Models
          Ok - that's an easier scope. Arbitrary change of the axis would appear awfully complex. Even flipping, mirroring appear to be a bit of a problem. But axis swapping should be doable without too much fuzz. (famous last words...?)
          • E Offline
            ericschimel
            Ok, I am seeing what you are thinking. Flipping would be awesome, because then, like I said, I could change the gluing plane of DC's without having to rebuild them.
            Later on, something that would mirror DC's would be killer, but that's a lot of math to wrap your brain around! (and how do you change small sections of formulas, instead of just swapping them around?)
            -Eric
            Custom Models
              That'd be the key problem. To interpret forums. Just seem all too complex.
              But let's have a look at swapping axis orientation.
              • E Offline
                ericschimel
                That would be really cool if axes could be rotated....
                As far as changing snippets of formulas, is it impossible with the API, or just really friggin hard?
                -Eric
                Custom Models
                  It's easy if you know what to change. But the formula is basically source code and they can appear in so many mutations, you'd have to make the script be able to understand what the formula do, its intention.
                  • E Offline
                    ericschimel
                    Ahh ok, but a script that would say go through a change all the "LenX" references to "LenY" references would be fairly easy?
                    -Eric
                    Custom Models
                      Yea - much easier.
                      But, what about sub-components? If you have multiple depths with components?
                      • E Offline
                        ericschimel
                        Oh yeah, there are always sub components, that's what makes this so hard to do. If I was just changing top level stuff, the script wouldn't be needed.
                        -Eric
                        Custom Models
                          Yea, but a the sub-components could themselves be DC's - would one have to flip the axis of these as well? Or would things work find if one only processed the first level of sub-components?
                          • E Offline
                            ericschimel
                            As far as sub components, it would be any sub components that reference the axis of the most top level component. And sub component that references an axis from another sub component that is below the top level wouldn't need to be changed.
                            -Eric
                            Custom Models
