    DC "Flipping" Script
    19 Posts 2 Posters 1.9k Views 2 Watching
    • E Offline
      ericschimel
      Ok, so here's a fairly basic DC. If I change the axis of the DC, it "blows up" because all of the formula's are referencing an axis that has changed.
      Pull this into your model, and use it to see how it works. Then, right click on it, and change the orientation of the axis and then try to use it again, you'll see what happens.
      E2000 Left Mitre.skp
      -Eric
      http://plugin.sketchthis.net
      Sketchup Kitchen Design Plugin
      Custom Models
        Will look at it.
        (Sorry - been a wee bit busy)
          hmm.. are we talking about just flipping, or adjusting axis completely?
          Is it swapping X for Y or Z etc?
          • E Offline
            ericschimel
            Lets say you took the above DC and rotate the axis about the Blue axis. In other words, you switched the direction of the green and red axis, leaving the blue one in the same direction. For the DC not to "Blow up" you'd need to switch every Red axis formula with Green axis references and vica versa, leaving the blue ones alone.
            Doing this manually is really tedious and dangerous, even on a simple DC such as this one.
            -Eric
            Custom Models
              Ok - that's an easier scope. Arbitrary change of the axis would appear awfully complex. Even flipping, mirroring appear to be a bit of a problem. But axis swapping should be doable without too much fuzz. (famous last words...?)
              • E Offline
                ericschimel
                Ok, I am seeing what you are thinking. Flipping would be awesome, because then, like I said, I could change the gluing plane of DC's without having to rebuild them.
                Later on, something that would mirror DC's would be killer, but that's a lot of math to wrap your brain around! (and how do you change small sections of formulas, instead of just swapping them around?)
                -Eric
                Custom Models
                  That'd be the key problem. To interpret forums. Just seem all too complex.
                  But let's have a look at swapping axis orientation.
                  • E Offline
                    ericschimel
                    That would be really cool if axes could be rotated....
                    As far as changing snippets of formulas, is it impossible with the API, or just really friggin hard?
                    -Eric
                    Custom Models
                      It's easy if you know what to change. But the formula is basically source code and they can appear in so many mutations, you'd have to make the script be able to understand what the formula do, its intention.
                      • E Offline
                        ericschimel
                        Ahh ok, but a script that would say go through a change all the "LenX" references to "LenY" references would be fairly easy?
                        -Eric
                        Custom Models
                          Yea - much easier.
                          But, what about sub-components? If you have multiple depths with components?
                          • E Offline
                            ericschimel
                            Oh yeah, there are always sub components, that's what makes this so hard to do. If I was just changing top level stuff, the script wouldn't be needed.
                            -Eric
                            Custom Models
                              Yea, but a the sub-components could themselves be DC's - would one have to flip the axis of these as well? Or would things work find if one only processed the first level of sub-components?
                              • E Offline
                                ericschimel
                                As far as sub components, it would be any sub components that reference the axis of the most top level component. And sub component that references an axis from another sub component that is below the top level wouldn't need to be changed.
                                -Eric
                                Custom Models
