    DC "Flipping" Script
    19 Posts 2 Posters 2.0k Views 2 Watching
      Can you give an example of an formula? Before and after?
      • E
        ericschimel
        Ok, so here's a fairly basic DC. If I change the axis of the DC, it "blows up" because all of the formula's are referencing an axis that has changed.
        Pull this into your model, and use it to see how it works. Then, right click on it, and change the orientation of the axis and then try to use it again, you'll see what happens.
        E2000 Left Mitre.skp
        -Eric
        http://plugin.sketchthis.net
        Sketchup Kitchen Design Plugin
        Custom Models
          Will look at it.
          (Sorry - been a wee bit busy)
            hmm.. are we talking about just flipping, or adjusting axis completely?
            Is it swapping X for Y or Z etc?
            • E
              ericschimel
              Lets say you took the above DC and rotate the axis about the Blue axis. In other words, you switched the direction of the green and red axis, leaving the blue one in the same direction. For the DC not to "Blow up" you'd need to switch every Red axis formula with Green axis references and vica versa, leaving the blue ones alone.
              Doing this manually is really tedious and dangerous, even on a simple DC such as this one.
              -Eric
              Custom Models
                Ok - that's an easier scope. Arbitrary change of the axis would appear awfully complex. Even flipping, mirroring appear to be a bit of a problem. But axis swapping should be doable without too much fuzz. (famous last words...?)
                • E
                  ericschimel
                  Ok, I am seeing what you are thinking. Flipping would be awesome, because then, like I said, I could change the gluing plane of DC's without having to rebuild them.
                  Later on, something that would mirror DC's would be killer, but that's a lot of math to wrap your brain around! (and how do you change small sections of formulas, instead of just swapping them around?)
                  -Eric
                  Custom Models
                    That'd be the key problem. To interpret forums. Just seem all too complex.
                    But let's have a look at swapping axis orientation.
                    • E
                      ericschimel
                      That would be really cool if axes could be rotated....
                      As far as changing snippets of formulas, is it impossible with the API, or just really friggin hard?
                      -Eric
                      Custom Models
                        It's easy if you know what to change. But the formula is basically source code and they can appear in so many mutations, you'd have to make the script be able to understand what the formula do, its intention.
                        • E
                          ericschimel
                          Ahh ok, but a script that would say go through a change all the "LenX" references to "LenY" references would be fairly easy?
                          -Eric
                          Custom Models
                            Yea - much easier.
                            But, what about sub-components? If you have multiple depths with components?
                            • E
                              ericschimel
                              Oh yeah, there are always sub components, that's what makes this so hard to do. If I was just changing top level stuff, the script wouldn't be needed.
                              -Eric
                              Custom Models
                                Yea, but a the sub-components could themselves be DC's - would one have to flip the axis of these as well? Or would things work find if one only processed the first level of sub-components?
                                • E
                                  ericschimel
                                  As far as sub components, it would be any sub components that reference the axis of the most top level component. And sub component that references an axis from another sub component that is below the top level wouldn't need to be changed.
                                  -Eric
                                  Custom Models
