    [Plugin] Selection Toys
    594 Posts 121 Posters 397.2k Views 121 Watching
    • mitcorbM Offline
      mitcorb
      @Thomthom:
      I seem to be having a problem with Selection Toys.
      I see it in plugins and I see Selection in drop down menu with a flyout trigger to the right, but nothing flies out. So I am unable to use the various selection tools.
      In case it is a conflict or interoperability issue, I will mention that I have downloaded in the last few days updates of Extrude edges, Grow, Projections v2 and I am experimenting with Sculpt. I have also, Hoverselect.
      I just thought you would want to know about this.
      Of course, the possibility exists that it has nothing to do with the plugins mentioned and I am just not activating Selection in the proper way.
      Nonetheless, thank you for the opportunity to use the plugin.
      mitcorb
        Can you open the Console and see if there's any error messages that appear there?
        • mitcorbM Offline
          mitcorb
          I will give that a try, and post back. Thanks
          • mitcorbM Offline
            mitcorb
            Thomthom:
            My apologies, it is not your plugin, but Matt Extend Tool that has the Selection with the fly out trigger. This time the fly out did happen and it says Extend edges. However, at this time, the Extend Edges is not working, and it may have to do with interoperability with other tools.
            Sculpt is currently not working, though I understand that it is still in development.
            By the way, at first I could get no activity in the Ruby Console with the dead end menu with "Selection >". Then, for some reason the fly out trigger '>' worked and Extend Edges flew out, and the console displayed that action, but no results from the selection. I will stop here, before it gets confusing.
              That's odd... Can't say I can provide any explanation to that. Poke Matt and let him know.
                • Added Layer filters
                • Added function to select all entities on selected layers
                  • Added function to select all active entities on selected layers
                  • Bob JamesB Offline
                    Bob James
                    @thomthom said:
                    Convert into Components - Converts all the group copies into components. Transformation and materials will be transferred.
                    Useful for when you have a model where groups where used instead of components.
                    Wow! Really useful.
                    Alas! When I load select_toys.rb it does not appear in the plugins dropdown ❓
                      All the menus are access via the context-menu. This is because the commands depends on the selection. Putting them all in the plugin menu would leave a huge number of menus that most of the time wouldn't do anything.
                        Bob James
                          japanNuke
                          thanks thomthom!
                          love this plugin, one of the best for me so far 😎
                          %(#BFBFBF)[be cool
                          be bad]
                          • CadFatherC Offline
                            CadFather
                            Hi Thom - just to let you know, the greyed-out menus are still there on my machine.
                            this only appears after some time working in SU, but i have not been able to pin the pattern so far..
                              I saw some weeks ago at the office, a model someone was working on caused some strange behaviour. When you kept right clicking on a selection you'd start finding menus greyed out. When you clicked outside the geometry, on empty model space, the menu's would work again.
                              This seemed to only happen on a particular model, and it happened on SU6 and 7 - even on a plain installation without any plugins.
                              Is this similar to what you see?
                                CadFather
                                no, happens all the time, many items go grey (including native SU menus) regardless of the model.
                                if i restart SU it works again for a while.. time limited demo mode : )
                                ..of course it may be clashing with other plugins, i will run a couple of empty folder test later today
                                  But removing Selection Toys instantly fixes this?
                                    CadFather
                                    yes Thom, all works well without....
                                    ..can't seem to detect the pesky pattern! 😠 i have a hunch it's something to do with groups, perhaps doing operation inside/outside etc..
                                    keeping my eyes open anyway as your plugin is a must.. will let you know
                                      Has it always been like this for you? Or is it a particular version where this started?
                                        CadFather
                                        not sure, i think i have noticed since the last 2 versions - but i could be wrong.. (erratic work)
                                        don't you notice it on your machine?
                                          No. I use it all the time when I work - also got co-workers that use it. Never had such problems. Which is why I'm at a loss to what it can be. If I can't reproduce it I have no idea what it could be.
                                          Maybe it's a plugin combo?
                                            CadFather
                                            um.. it must be a clash then.. with all the gems in the folders we're in need of the 'new-spot-the-clash-finder-ruby-please'
                                            • 29
                                            • 30
                                            • 5 / 30
