    [Plugin] Hole Punching Tool
    200 Posts 43 Posters 243.2k Views 43 Watching
      Following some feedback...
      Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=271170#p271170
      Components exactly matching wall-depth glitch fixed.
      Zero depth in dialog trapped.
      ๐Ÿค“
        Ah yes, seems thas was also a video about this tricky tips ๐Ÿ‘
        But all that is very "manual" ๐Ÿ˜„
        Automatic is more pleasant ๐Ÿ˜‰
        It's was this one โ˜€
        [flash=480,385:344mybyx]http://www.youtube.com/v/_ALbktAE9C8?fs=1&hl[/flash:344mybyx]
          Why don't put by default infinite depth, and just set depth if wanted? ๐Ÿ˜‰
          • david_hD Offline
            david_h
            So far. . .so good.
            Thanks TIG.
            D
              Because if there were no 'inner-face' to the wall how would it know when to stop extruding the reveals ?
              You could add say 1000m as the maximum punch depth and this would be remembered in the model... BUT then if there were ever a wall with no inner-face you'll get v_e_r_y deep reveals ! The 20"/500mm default seems a reasonable depth to start off with ?
              • EarthMoverE Offline
                EarthMover
                Is it only supposed to punch a hole if the punch depth matches the wall thickness exactly? If I put in a depth greater than the wall thickness, I get no punch....is this correct?
                BTW - Thanks TIG for finishing this up and publishing!
                Content Creator at Skapeup
                  Cousin Component Punch punches all the volume without to know the size? ๐Ÿ˜‰
                  don't launch the script โ“
                    The way it works is you set the maximum punched depth [the default is 20"/500mm, but you can permanently change it for that model at any time] - just decide on a value knowing that all your various wall thicknesses are probably always less than that.
                    The holes are them punched to match the actual wall thickness, IF it's =20" or less [the hole's reveals also match the inner-face material/layer] - BUT if you have a one-face wall [or a very thick wall] then the reveal depth is made as the maximum =20" [and the reveals then match the outer-face material/layer].
                    The code that checks for the inner-face is still not perfect - but I am sleeping on it...
                    Currently a 'ray' is cast internally from the front-face, centered on the cutting-component instance, until it finds a suitable face that's parallel and facing the right way. If there isn't one it then uses the default reveal size... It's currently possible to trip it up if your component also has a face/edge exactly on the center and at the same distance from the front-face as the real candidate for the inner-face - the ray can mistakenly find that instead of the required face and so it misses it and 'defaults the reveal depth... I suspect this is your case ???
                    It is possible to test in other ways - for let's say faces' planes and points being 'on' them at the correct 'thickness'... so I just need to think up some better coding solutions - maybe tomorrow - I'm tired now........... ๐Ÿค“
                      EarthMover
                      For me, the raytest seems to miss the parallel wall in every case where my depth is greater than the wall thickness. I'm just using generic SU windows to test, but also tried with simple shape components I made myself to be sure there was no line in the direct center. Every time it seems to be punching through to the bounds of the punch depth. No worries though, I typically offset my walls to the same thickness, so I can just math the punch depth with that and all is well. Overall, it's a great solution for an age old ruby puzzler. ๐Ÿ‘
                        Adam
                        I'm making a more robust version now and will post it later today....... ๐Ÿ˜‰
                          rv1974
                          Hi! I have hard times trying to copy or simply select the punched components. Could you improve it?
                          P.S. A science fiction request: Could it punch on multiple feces or at least corner windows (2 faces)?
                          punch.skp
                            rv1974
                            You are making life more difficult for yourself than it needs to be...
                            You components are made exactly the depth of the wall ! This means that the reveals are obscured by the component itself...
                            Why not make them a simple 2D rectangle cutting-component that you place on the outer-face, and you then let the 'Hole Punching...' make the hole's reveals and the hole in the inner-face etc - that way the wall thickness could vary and the reveals will adjust to suit for the one 2D component - and is then more easily selected too.
                            You CAN select the component-instances using the Outliner as needed...
                            Please read the tool's notes... you should NOT 'copy' component-instances that are 'punched' [unless you are going to 'unlink the punches' or 'undo the punching' immediately afterwards], because the observers and linking attributes etc will get 'tangled up'. So usually you should only copy un-punched component-instances - but remember that if they are punched you can always use: select them > 'undo punch' > do the copying > re-select them > 'punch' again... ๐Ÿ’ญ
                            I've only just got this single wall hole-punching working and now you want punched corner windows - aaaargh! ๐Ÿ˜’ ๐Ÿ˜‰
                              Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=271170#p271170
                              The finding the inner-face methods have been made more robust - now an inner-face will only be used if it is the correct orientation / side of the wall, AND it is within the specified maximum depth from the outer-face, AND its geometry overlaps at least the center of the component-instance, AND if there are several suitable 'candidate' faces then it is taken as the one 'nearest' to the outer-face.
                              Also an 'Unlink Punch' option has been added - this will 'unlink' a selected component-instance and its punched-hole geometry.
                              Please read the Notes... ๐Ÿค“
                                EarthMover
                                Thanks TIG for the update! ๐Ÿ‘ It works in every case I've tried now. Flawless thus far.
                                  EarthMover
                                  One foreseeable issue. I have a lot of modified components where a glue/cut component is nested inside a larger component.....i.e. a window with shutters and mantle. Is there a way to either search the component for a nested cutting component and make the cut with that, or allow me to perform the cut from within the components edit mode?
                                  (Attached is a component I made for testing.)
                                  Windows with shutter and brick mantle.skp
                                    Bertier
                                    great thank you
                                    same thing with the name changing in chrome...
                                    will use #
                                      Bertier
                                      not working in SU 7
                                        @bertier said:
                                        not working in SU 7
                                        It works in v7 or v8...
                                        A little more detail please ๐Ÿ˜’
                                        I'm not psychic...
                                          Bertier
                                          sorry
                                          I put it in my pluggin folder
                                          it doesn't show up in my pluggin list...
                                          using SU7 on XP pro
                                            EarthMover
                                            Bertier,
                                            It's context sensitive. It only shows up in the right click menu when you have a component selected that has a "cut opening" value assigned to it. It's not in my plugin list either.
                                            • 2 / 10
