    Gabion Baskets
    11 Posts 8 Posters 5.2k Views 8 Watching
    • massimoM
      massimo Moderator
      Thank you for sharing! πŸ‘
      • olisheaO
        olishea
        I wish I had this model about 6 months ago!! fantastic πŸ‘
        oli
        • RichardR
          Richard
          Mate I bet you do!
          Hey Bocomofo thanks so much for sharing these!
          If I make any changes I'll load them back up!
          BUILTBRAND.COM.AU
          • B
            bocomofo
            That would be much appreciated!
            I know they are quite heavy and I thought about trying to make them a bit lighter, but just haven't had the time yet.
            I originally used skethcphysics to get the rocks to tumble into the baskets but they didnt pack as tightly as I'd hoped. I'm pretty sure there is room for improvement.
            If anybody has any recomendations for improving I'd try to take a look at.
            • urgenU
              urgen
              ....good model,bocomofo!..thanks! πŸ‘
              ....some fast hypershot+photoshop....
              --pupil forever...------
              • RichardR
                Richard
                Hmmmm! Thats a cool trick! yes I notice a few rocks defying gravity! πŸ˜„
                Though something great to start with!
                BUILTBRAND.COM.AU
                  malbert
                  Nice model bocomofo, thanks. Great to see the rocks are being put to good use. I didn't know about Sketchyphysics so I'll have to try it. I'm working on software to pack the rocks so they are a tighter fit. You can see the first attempt as the dry-stone wall in the intresto collection in 3dwarehouse. Real-world gabions often have the rocks visible on the front face arranged manually and the rocks behind poured in via a chute. The tighter packed rocks on the front face gives them a neater appearance. I'm working on it. Yours look pretty good though.
                  Malbert (aka intresto)
                    malbert
                    Great model bokomofo.
                    I had a play with sketchyphysics and found that if I define each rock as a convex hull they fall against each other quite naturally so no floating rocks. See attached image. The left hand image is from the original non-physics collection of rocks (the dry stone wall in the intresto collection on 3dwarehouse), the middle image are the convex hull rocks moved apart so they don't intersect and the right hand image after letting them fall inside a hidden container. Don't know why the textures changed when I turned the rocks into convex hulls.
                    1.non-physics rocks 2. physics convex hulls before and 3. after falling into hidden container
                      JJOKLONG
                      Thanks you very much bokomofo. 😍
                      • N
                        notareal
