    Gabion Baskets
    11 Posts 8 Posters 5.1k Views 8 Watching
      bocomofo
      Model of Gabion baskets attached if anybody would like ot use it.
      I've tried to make the file as managable as possible but it is quite heavy on the faces and edges, so it probably makes sense to use the layers to switch off the rocks until ready for export.
      It renders quite nicely too.
      I've also attahced an elevation render, which makes a good sketchup material for when the gabions are off in the distance, as well as (very) rough bump map to give it a bit of depth.
      j
      ps rocks courtesy of 'intresto' at the 3DWH
      gabion.zip
      Gabion_mat+bump.zip
      • massimoM Offline
        massimo Moderator
        Thank you for sharing! πŸ‘
        • olisheaO Offline
          olishea
          I wish I had this model about 6 months ago!! fantastic πŸ‘
          oli
          • RichardR Offline
            Richard
            Mate I bet you do!
            Hey Bocomofo thanks so much for sharing these!
            If I make any changes I'll load them back up!
            [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
              bocomofo
              That would be much appreciated!
              I know they are quite heavy and I thought about trying to make them a bit lighter, but just haven't had the time yet.
              I originally used skethcphysics to get the rocks to tumble into the baskets but they didnt pack as tightly as I'd hoped. I'm pretty sure there is room for improvement.
              If anybody has any recomendations for improving I'd try to take a look at.
              • urgenU Offline
                urgen
                ....good model,bocomofo!..thanks! πŸ‘
                ....some fast hypershot+photoshop....
                --pupil forever...------
                • RichardR Offline
                  Richard
                  Hmmmm! Thats a cool trick! yes I notice a few rocks defying gravity! πŸ˜„
                  Though something great to start with!
                    malbert
                    Nice model bocomofo, thanks. Great to see the rocks are being put to good use. I didn't know about Sketchyphysics so I'll have to try it. I'm working on software to pack the rocks so they are a tighter fit. You can see the first attempt as the dry-stone wall in the intresto collection in 3dwarehouse. Real-world gabions often have the rocks visible on the front face arranged manually and the rocks behind poured in via a chute. The tighter packed rocks on the front face gives them a neater appearance. I'm working on it. Yours look pretty good though.
                    Malbert (aka intresto)
                      malbert
                      Great model bokomofo.
                      I had a play with sketchyphysics and found that if I define each rock as a convex hull they fall against each other quite naturally so no floating rocks. See attached image. The left hand image is from the original non-physics collection of rocks (the dry stone wall in the intresto collection on 3dwarehouse), the middle image are the convex hull rocks moved apart so they don't intersect and the right hand image after letting them fall inside a hidden container. Don't know why the textures changed when I turned the rocks into convex hulls.
                      1.non-physics rocks 2. physics convex hulls before and 3. after falling into hidden container
                        JJOKLONG
                        Thanks you very much bokomofo. 😍
                        • N Offline
                          notareal
                          Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
