    • Log Masuk
    A Welcome Message to New SketchUcation Members
    Scheduled Pinned Kunci Moved Newbie Forum
    1.4k Kiriman 667 Posters 656.5k Lihat 667 Watching
    Memuatkan lagi kiriman
    • Lama ke Baru
    • Baru ke Lama
    Balas
    Log masuk untuk balas
    Topik ini telah dipadam. Hanya pengguna dengan kuasa pengurusan boleh melihatnya.
    • mitcorbM Luar talian
      mitcorb
      If you have been observing any prior to posting you will note that this is the friendliest, most helpful forum on the planet or above the planet or around the planet. Welcome. Many are here to help because many have helped them. Now, why would anyone want to do that? 💚
      1 Reply Last reply Balas Petikan 0
      • D Luar talian
        d12dozr
        Welcome, Jay! Great post there 👍
        So to rendering and animation, materials (and animated materials), light sources, bump maps, UV mapping, and other such. I have gathered a list of products to look into (in no particular order), of which I've already played with a few: IDXrender, Podium, V-Ray, Piranesi, Shaderlight, Kerkythea, Thea Render, fryrender, Indigo Renderer, Irender nXt, Silex, Artlantis, LuxRender, LightUp, and Vue.
        The final output doesn't have to be quite at the level of photo realistic, since by the subject matter people will know it's not really photography (and some of the products only exist as models anyhow). Still, the closer the better.
        About that list: I'd be glad to hear of something I've overlooked (via pm would be good, but suit yourself).
        For animation I've been poking around with Proper Animation, SketchyPhysics, and Sketch Talk++ with Ruby Console Pro - mainly focusing on SketchyPhysics. I'm surely open to suggestion on those too...
        Have you looked at Twilight Render? It will actually render SketchyPhysics animations, which is a unique ability among Sketchup renderers I believe. See this post for an excellent example 😉
        http://goo.gl/f7ooYh
        • C Luar talian
          carlm
          Hi - I'm a woodworker, pretty new to SU. I think I'm having an "if I knew what it was called I could look it up" problem; it has to have been asked and answered a zilllion times but...
          If I design, for example, a table -- all the joinery, dimensions, etc. -- and then my client wants it to be shorter/wider/taller/whatever, how do I insert/remove a slice from the middle? If I use the Scaling tool, everything stretches or compresses, so if for example I make it longer, the legs go oblong, the end overhangs increase, even the end aprons get thicker in proportion...
          I think I want to create two section planes and then move them together or apart, but maybe that's how wome other program does it.
          Thanks, -Carl-
          • GaieusG Luar talian
            Hi Carl and welcome to SCF!
            The Move tool will be the one to use here (maybe in different, separate steps however).
            With a left-to-right selection box, select one half of the table (in my example). This way you will only select what is fully and completely inside the selection box.
            See how only things on that side are selected - now with the Move tool, start stretching (or shrinking) the middle part. Make sure to do this along a convenient direction (like an axis in my example).
            You can lock the Move tool on the axes with the arrow keys;
            left = green,
            Right = red,
            up/down = blue.
            Then there is always Fredoscale of course but first learn it the native, SketchUp way...:
            http://forums.sketchucation.com/viewtopic.php?t=17948
            • C Luar talian
              carlm
              Gai- Thanks! In action this doesn't look like it should work, but it's exactly what I needed! I expect I missed this in the tutorials last summer... Locking the movement direction really helps to avoid 'unexpected' results! Thanks again, -Carl-
              • D Luar talian
                dealduck
                Hi, I introduce zalie from Indonesia and want to know much about the Sketchup ... yes please be guided 👍 👍
                • G Luar talian
                  georgeo
                  Hello everyone, I'm called George desenhiosta designer furniture. I'm new to forum and want to learn a lot with you. Thanks Gustavo 😄
                  • N Luar talian
                    NicolasM
                    Hello !
                    I'm new to SU and already having problems 😞
                    You can visit my models at http://sketchup.google.com/3dwarehouse/search?viewer=0318254298444948657821582&scoring=m
                    Shears,
                    Nico.
                    • TIGT Luar talian
                      @nicolasm said:
                      Hello !
                      Nico.
                      Ask some specific questions and we'll try to help you...
                      • A Luar talian
                        ALFRED
                        Hello! My name is Pavel, from Russia. I am a new user of this forum, and me am very difficult to be guided here as english I know isn't very good yet. Say me please, in what topic would be possible to ask a question on a plugin which to me it would be desirable to use or offer idea about creation of a certain plug-in to the advanced users writing plug-ins? I am not able to work yet with it.
                          Hi Pavel and welcome!
                          I am not sure what exactly you want; a plug-in to help write an(other) plug-in???
                          • Z Luar talian
                            zitoun
                            Hello there !
                            I'm currently trying to have a miniature plane flying in front of the camera in a small room (Airfix Dogfighter like...) and I'd like to thank a lot Pixero and Fredo whose work is VERY handy.
                            I manage to have some kind of nice curve for my camera motion, I now need to see how I will animate my plane relatively to the camera... Scripts is the way to do that, I think.
                            Anyway, thanks a lot and continue the good work !
                            The light at the end of the tunnel is a train.
                            • S Luar talian
                              stada
                              Hi there!
                              For an introduction you could go to the Official SU blog, since I am the most recent "Featured Modeler" in this blog. I was watching an online video about the Sketchup Basecamp (I dream to be there once). In the speech this SketchUcation site was mentioned. I had been visiting it already but registrated only today.
                              I am a fanatic Geo-modeler but want to learn more about rendering and Ruby things as well.
                              For dutch SUpers: I have a weblog.
                              Thanks,
                              Dick Stada
                                Hi Dick and welcome! Nice to have some more geo-modellers aboard!
                                We have a dedicated "GE Subforum" under the main SU Forum if you are interested. 😉
                                • A Luar talian
                                  ALFRED
                                  I would like to express idea in a topic, but I do not know what, and whether there is it, on a writing of plug-ins pluginsmakers for a writing of those plug-ins, hope you me understood? Thanks.
                                    Okay, I think I understand. You have an idea and would like to ask if somebody could write a plugin for that.
                                    I think best would be to go to the Plugins Forum and start a new topic with the [REQUEST] word in the subject. Just like this one for example:
                                    http://forums.sketchucation.com/viewtopic.php?f=323&t=30931
                                    • G Luar talian
                                      gojohnson
                                      Oh Yeah. I almost forgot. Hello World.
                                      • D Luar talian
                                        Death_SpecteR-9
                                        Hi, I'm new here.
                                        I'm a SketchUp abuser.
                                        Oh stop with the "Jello World" already people. 😎
                                        • J Luar talian
                                          jp261
                                          Hi everyone, I'm new new here. I recently downloaded the free version 8 and I am having problems getting plugins to work. Im on a PC with windows 7. Any help would be appreciated. I look forward to learning a lot here. Thanks!
                                            mitcorb
                                            Welcome jp261:
                                            Sketchup 8 is new and many plugins were designed based on either v6 or v7, unless otherwise noted. Some of these may not have been updated. Best to post your issue in the specific plugin thread/topic so that the author can respond and make suggestions and updates.
                                            • 61
                                            • 62
                                            • 63
                                            • 64
                                            • 65
                                            • 72
                                            • 73
                                            • 63 / 73
