    Section Plane
    14 Posts 3 Posters 665 Views 3 Watching
      Pout
      From the API:
      ***"The SectionPlane class contains methods to get and set the plane for the SectionPlane in a model. Note that there is no way to get a SectionPlane object using Ruby. You must manually create a section plane with the Section Plane Tool in SketchUp and then query the entities array to find the SectionPlane object. This class was primarily added for compatibility with a third-party software product.
      One workaround that does work: you could create a SketchUp model that contains nothing but a SectionPlane, then import that as a component into whatever model you wish to add a SectionPlane to."***
      But, it's impossible to create a section plane in an empty drawing. Correct?
      What i want to do is:
      Automatically generate a section plane for each group (highest level) or component instance in a model.
      Group that section plane with that group or component instance so the plane only cuts that specific entity.
      A work arround could be: let the user create 1 section plane and copy that.
      But maybe there is a better, more logic way?
        In TT_Lib I have a wrapper that load a component with a section cut from the subfolder of the library.
        But! There is more problems with sections cuts:
        No way to set or get the active cut.
        SectionCuts = PITA
          Pout
          i was just looking into that set/get active cut
          when you make a copy one of them gets set as non-active, so that is not an option.
          I'll have a look into that TT_Lib
          PITA? Like in FUBAR? πŸ˜„
            Pretty much.
            My TT_Lib only inserts - no get/set. 😞
              Even if you set the section-plane inside the imported component as active, when you explode the component the section-plane ceases to be active ?
                Yes.
                  Pout
                  well there goes my idea of letting a section plane move over a period of time for each individual group/instance 😞
                  back to the drawing board!
                    mhm another show stopper... 😞
                      Pout
                      For verification:
                      It is impossible to create a section plane through the ruby API
                      Its is impossible to move (transform!) a section plane through the ruby API
                      It is possible to delete a section plane through the ruby API (erase!)
                      Is this correct?
                      Thx!
                        Aye, a SectionPlane inherits Sketchup::Drawingelement - so all the methods of Sketchup::Drawingelement and Sketchup::Entity is available.
                        ` Sketchup::SectionPlane.ancestors
                        [Sketchup::SectionPlane, Sketchup::Drawingelement, Sketchup::Entity, Object, Kernel]`
                        The only thing is that you don't get any methods that relates to how a sectioncut function other than being able to get or set the plane.
                          Pout
                          ThomThom,
                          you got me a bit confused now.
                          I seem to be unable to move (translation) a section plane by the blue axis through API.
                          But since it is an entity, i should be able to do it?
                          thx
                            Pout
                            ok, a bit in shame I confees that I can move a section plane but only by certain axis.
                            I do have to do it like this though:
                            ent=Sketchup.active_model.selection[0] # a sketchup section plane
                            vector = Geom;;Vector3d.new 0,0,-3
                            t = Geom;;Transformation.translation vector
                            Sketchup.active_model.entities.transform_entities(t,ent)
                            ent.transform! or ent.transformation does not work
                            Now, let's say i have 2 groups, each with a section plane in them.
                            First one i want to move -3 over z-axis, the other one -1 over z-axis.
                            This can be done?
                            But auto-creation of a section plane for (and in) each group is not possible i suppose
                              ent.transform! and ent.transformation is not part of Sketchup::Entity or Sketchup::Drawingelement. They are part of Sketchup::Group and Sketchup::ComponentInstance.
                              This can be done?
                              Entities.transform_by_vectors
                              http://code.google.com/apis/sketchup/docs/ourdoc/entities.html#transform_by_vectors
                              "Auto-creation"?
                              You can only add a section plant to a model by inserting a component with a section plane and then exploding the inserted instance. Bit of a hack. But you won't be able to activate it.
                                Pout
                                ThomThom, thx for the answers!
                                With auto-creation I mean this:
                                The creation through ruby of a section plane in each of the 20 groups that are in the model.
