    Section Plane
    14 Posts 3 Posters 1.4k Views 3 Watching
      Even if you set the section-plane inside the imported component as active, when you explode the component the section-plane ceases to be active ?
        Yes.
        • P
          Pout
          well there goes my idea of letting a section plane move over a period of time for each individual group/instance 😞
          back to the drawing board!
            mhm another show stopper... 😞
            • P
              Pout
              For verification:
              It is impossible to create a section plane through the ruby API
              Its is impossible to move (transform!) a section plane through the ruby API
              It is possible to delete a section plane through the ruby API (erase!)
              Is this correct?
              Thx!
                Aye, a SectionPlane inherits Sketchup::Drawingelement - so all the methods of Sketchup::Drawingelement and Sketchup::Entity is available.
                ` Sketchup::SectionPlane.ancestors
                [Sketchup::SectionPlane, Sketchup::Drawingelement, Sketchup::Entity, Object, Kernel]`
                The only thing is that you don't get any methods that relates to how a sectioncut function other than being able to get or set the plane.
                • P
                  Pout
                  ThomThom,
                  you got me a bit confused now.
                  I seem to be unable to move (translation) a section plane by the blue axis through API.
                  But since it is an entity, i should be able to do it?
                  thx
                  • P
                    Pout
                    ok, a bit in shame I confees that I can move a section plane but only by certain axis.
                    I do have to do it like this though:
                    ent=Sketchup.active_model.selection[0] # a sketchup section plane
                    vector = Geom;;Vector3d.new 0,0,-3
                    t = Geom;;Transformation.translation vector
                    Sketchup.active_model.entities.transform_entities(t,ent)
                    ent.transform! or ent.transformation does not work
                    Now, let's say i have 2 groups, each with a section plane in them.
                    First one i want to move -3 over z-axis, the other one -1 over z-axis.
                    This can be done?
                    But auto-creation of a section plane for (and in) each group is not possible i suppose
                      ent.transform! and ent.transformation is not part of Sketchup::Entity or Sketchup::Drawingelement. They are part of Sketchup::Group and Sketchup::ComponentInstance.
                      This can be done?
                      Entities.transform_by_vectors
                      http://code.google.com/apis/sketchup/docs/ourdoc/entities.html#transform_by_vectors
                      "Auto-creation"?
                      You can only add a section plant to a model by inserting a component with a section plane and then exploding the inserted instance. Bit of a hack. But you won't be able to activate it.
                      • P
                        Pout
                        ThomThom, thx for the answers!
                        With auto-creation I mean this:
                        The creation through ruby of a section plane in each of the 20 groups that are in the model.
