    Need a hatch ruby
    6 Posts 4 Posters 816 Views 4 Watching
      Jorgensen
      I'm at creating some illustations where I need some hatches on some faces.
      Does anyone know if there is a Ruby plugin that can help me ?
      The function could be - select face > hatch in content menu > axe > specific distance / random distance > layer ?
      Thanks 😄
        d12dozr
        TIG's 2D tools has a hatch function...search the Plugins subforum.
        http://goo.gl/f7ooYh
          Why not just use textures?
            Jorgensen
            hi
            @d12dozr
            I will look into that
            @thomthom
            sorry, I did't mention that it has to be affected by the seleced style... but I could give it a go with texture
              My 2Dhatch Tool applies a material that is made using a selection from a folder of 'tiling' jpg images [customizable content] as textures based on the standard ACAD hatch.pats...
              So in essence it's basically a collection of hatch-pattern images that you could use yourself in any material BUT which it uses to make the material etc for you automatically... 🤓
                Jorgensen
                Hi TIG
                Thanks for your input.
                As i wrote, I was looking for a script that could split a face so it became a part of the model as lines, so they could have the same style as other lines in the drawing. I hoped that protrude would help me - but I can't get it to work 😞
                I have added an image that shows the result - I have to add the lines manuel.
