    [Plugin] Component Spray Tool 1.3.
    92 Posts 44 Posters 99.2k Views 44 Watching
    • Didier BurD Offline
      Didier Bur
      Hi tt,
      DB
      • I Offline
        inbal
        thank so much 😄
          lapx
          Problems with component spray tool...Tool will not pick point after clicking.
          Is anyone else have problems with the tool? All the parameters appear correct.
          I'm placing byce on a simple plane is not working. Openig a new drawing helped but it always goes back to not working at some point.
          I'm using in V6.
          • charly2008C Offline
            charly2008
            I wanted to try compo spray but I get a huge number of components at a small circle. What am I doing wrong?
            Charly
              Didier Bur
              Did you draw a great circle (20m or so) or a small one (2m or so) ?
              But don't worry, since FaceMe components don't really have a bounding box, the number of components to be created is wrong, if I remember well...
              Regards,
              DB
                charly2008
                Hi Didier,
                The circle was about three meters. I tried the whole day. If i use it at a single line or a point then i get very small copies.
                Charly
                Untitled.skp
                  charly2008
                  For the above mentioned problem i found the solution. The values for Low and high scale where to less.
                  But now although Keep vertical is selected, the tree is horizontal. For this I could not find the reason.
                  Charly
                    charly2008
                    I found the error. This component was the reason. After I exploded the component and made it a new component, the error was gone.
                    Charly
                    • mariochaM Offline
                      mariocha
                      I'm having difficulty to make it work in SU 8.
                      Confirmation ?
                      But it is my first try, I must say.
                      %(#008000)[Mario C.
                        Confirmation ?
                        Exactly what isn't working?
                        • mariochaM Offline
                          mariocha
                          Well, like I said it was my first try. I finally got it after a few more tries.
                          My mistake was to try to "spray" on a face in a group being outside of it.
                          Somehow I assumed that's what it did. 😳
                          Maybe cause I cannot get the "selection" option to work. It just stops and asks to select objects, even when a face is selected before, and it stays suck there, clicking or enter do nothing.
                          I read the manual, again (very well done btw). Maybe a warning line could be added about groups. 😄
                          Although it is so obvious now.
                          %(#008000)[Mario C.
                            koolarsenal
                            @didier bur said:
                            Hi all,
                            Here is an update of the component spray tool (updated PDF doc included).
                            What's new in 1.3.:
                            New "shape" option to drop component at each vertex of selected faces.
                            Bug fix when loading the script on Mac.
                            Bux fix that froze the script when no destination layer were specified.
                            Enjoy !
                            EDIT:
                            Last version posted 03.09.10 (no more progressbar conflict, not an rbs)
                            http://i883.photobucket.com/albums/ac36/koolarsenal/1.jpg
                            This is my problem with the plugin, can you tell me how to fix it? The table is to big, It isn't match with my screen so I can't see the rest of the table.
                              compadre.lucas
                              thank you so much!!.I;ve been dreaming about this tool for months.
                              I will try it out now.
                              sketchup is infinity.
                                bitslapped
                                I initially could not get this to work in selection mode, but it worked fine after removing all my other plugins. Must be some incompatibility, I have quite a few.
                                One thing I did notice is a tendency for scattered objects to be more dense toward the centre of the regions in all cases. I don't know ruby but it seems whatever random function you are using is a bit biased towards the mean.
                                That being said, what a fantastic script! Keep up the good work Didier!
                                  @Kool
                                  AS you have just 3 box values missing
                                  Just enter your values then press TAB
                                  and at the end Press Enter
                                  Some rustic but efficient 😉
                                  Below box values missing
                                    Didier Bur
                                    Hi all,
                                    I'm on my way to the next release to fix all these minor problems, and to add a webdialog as well.
                                    DB
                                      @charly2008 said:
                                      Charly
                                      Maybe it was very small in size. What if you Right-Click and choose Scale Definition?
                                        @didier bur said:
                                        Hi all,
                                        [attachment=0:3sz6k615]<!-- ia0 -->cs2.gif<!-- ia0 -->[/attachment:3sz6k615]
                                        That's very cool! 👍 😄
                                        Can I just come with a request? Make one multi-select list to pick the components, instead of a fixed 6 slots. And if the selected components can be preselected, that'd be a great user experience addition.
                                          Thanks a bunch for the new version!!!
                                          When we are at it; could you also add a function whether the tool sprays with that centralized way on a face it does at the moment or not (so that in some ways it would work similarly to the fur plugin or something like "populate")?
                                          Also, beside the sliders, will the fields accept precise, manual input too?
                                            penumbra
                                            Does it work on 2013? When trying to do a circle spray the plugin will not accept the second point of the circle (or any of the available shapes for that matter).
                                            • 5 / 5
