    [Plugin] Component Spray Tool 1.3.
    92 Posts 44 Posters 99.2k Views 44 Watching
      Didier:
      If you replace the native model.raytest with this method the rays won't stop on invisible entities:
        # Raytrace method that does not stop on hidden entities.
        def self.raytest(ray)
          model = Sketchup.active_model
          vector = ray[1]
          while true
            # Shot ray
            test = model.raytest(ray)
            return nil if test.nil?
            # Verify visibility
            point, path = test
            if path.all? { |e| e.visible? && e.layer.visible? }
              return test
            else
              # raytest stopped on a hidden entity - create a new ray from that point
              # and let the loop continue until it hits something visible, or nothing.
              ray = [ point, vector ]
          end # while
      • Didier BurD Offline
        Didier Bur
        Hi tt,
        DB
        • I Offline
          inbal
          thank so much 😄
            lapx
            Problems with component spray tool...Tool will not pick point after clicking.
            Is anyone else have problems with the tool? All the parameters appear correct.
            I'm placing byce on a simple plane is not working. Openig a new drawing helped but it always goes back to not working at some point.
            I'm using in V6.
            • charly2008C Offline
              charly2008
              I wanted to try compo spray but I get a huge number of components at a small circle. What am I doing wrong?
              Charly
                Didier Bur
                Did you draw a great circle (20m or so) or a small one (2m or so) ?
                But don't worry, since FaceMe components don't really have a bounding box, the number of components to be created is wrong, if I remember well...
                Regards,
                DB
                  charly2008
                  Hi Didier,
                  The circle was about three meters. I tried the whole day. If i use it at a single line or a point then i get very small copies.
                  Charly
                  Untitled.skp
                    charly2008
                    For the above mentioned problem i found the solution. The values for Low and high scale where to less.
                    But now although Keep vertical is selected, the tree is horizontal. For this I could not find the reason.
                    Charly
                      charly2008
                      I found the error. This component was the reason. After I exploded the component and made it a new component, the error was gone.
                      Charly
                      • mariochaM Offline
                        mariocha
                        I'm having difficulty to make it work in SU 8.
                        Confirmation ?
                        But it is my first try, I must say.
                        %(#008000)[Mario C.
                          Confirmation ?
                          Exactly what isn't working?
                          • mariochaM Offline
                            mariocha
                            Well, like I said it was my first try. I finally got it after a few more tries.
                            My mistake was to try to "spray" on a face in a group being outside of it.
                            Somehow I assumed that's what it did. 😳
                            Maybe cause I cannot get the "selection" option to work. It just stops and asks to select objects, even when a face is selected before, and it stays suck there, clicking or enter do nothing.
                            I read the manual, again (very well done btw). Maybe a warning line could be added about groups. 😄
                            Although it is so obvious now.
                            %(#008000)[Mario C.
                              koolarsenal
                              @didier bur said:
                              Hi all,
                              Here is an update of the component spray tool (updated PDF doc included).
                              What's new in 1.3.:
                              New "shape" option to drop component at each vertex of selected faces.
                              Bug fix when loading the script on Mac.
                              Bux fix that froze the script when no destination layer were specified.
                              Enjoy !
                              EDIT:
                              Last version posted 03.09.10 (no more progressbar conflict, not an rbs)
                              http://i883.photobucket.com/albums/ac36/koolarsenal/1.jpg
                              This is my problem with the plugin, can you tell me how to fix it? The table is to big, It isn't match with my screen so I can't see the rest of the table.
                                compadre.lucas
                                thank you so much!!.I;ve been dreaming about this tool for months.
                                I will try it out now.
                                sketchup is infinity.
                                  bitslapped
                                  I initially could not get this to work in selection mode, but it worked fine after removing all my other plugins. Must be some incompatibility, I have quite a few.
                                  One thing I did notice is a tendency for scattered objects to be more dense toward the centre of the regions in all cases. I don't know ruby but it seems whatever random function you are using is a bit biased towards the mean.
                                  That being said, what a fantastic script! Keep up the good work Didier!
                                    @Kool
                                    AS you have just 3 box values missing
                                    Just enter your values then press TAB
                                    and at the end Press Enter
                                    Some rustic but efficient 😉
                                    Below box values missing
                                      Didier Bur
                                      Hi all,
                                      I'm on my way to the next release to fix all these minor problems, and to add a webdialog as well.
                                      DB
                                        @charly2008 said:
                                        Charly
                                        Maybe it was very small in size. What if you Right-Click and choose Scale Definition?
                                          @didier bur said:
                                          Hi all,
                                          [attachment=0:3sz6k615]<!-- ia0 -->cs2.gif<!-- ia0 -->[/attachment:3sz6k615]
                                          That's very cool! 👍 😄
                                          Can I just come with a request? Make one multi-select list to pick the components, instead of a fixed 6 slots. And if the selected components can be preselected, that'd be a great user experience addition.
                                            Thanks a bunch for the new version!!!
                                            When we are at it; could you also add a function whether the tool sprays with that centralized way on a face it does at the moment or not (so that in some ways it would work similarly to the fur plugin or something like "populate")?
                                            Also, beside the sliders, will the fields accept precise, manual input too?
                                            • 5 / 5
