    [Plugin] Cloud.rb for SU6
    54 Posts 18 Posters 52.7k Views 18 Watching
    • GaieusG
      Well, that's a large one for sure!
        Arkadiusz
        @Didier Bur
        Great Work! Your scripts are very useful.
        @TaffGoch
        Thanks for helpfull info!
        “Do not go where the path may lead; go instead where there is no path and leave a trail”
        Btw, I'm looking for *.rb to approximate edge from cloud points.
        "I'd rather be hated for who I am, than loved for who I am not."
          SAnderka
          Just tried the plugin with both SU6 free and SU7 free, but after selecting a file (even example.dat provided by the author) in the "select points cloud file" dialog, nothing happens.
          Are there any dependencies that I'm missing?
            johnpa
            Take a look at this post and download the revised script and you should be good to go. The link to the script is in the post at the top of the thread.
            404 Not Found
            (forums.sketchucation.com)
            JP
              SAnderka
              404 Not Found
              JP
              Awesome, thanks!
              There is one interesting thing: The plugin won't work on my PC if i copy the examples.dat on my desktop. If I copy it anywhere else, it works just fine, but locating it on the desktop just reproduces the "nothing happens" error it reported above...
              EDIT: Some further testing revealed that the plugin can't handle umlauts in directory names (my user account contains a German umlaut). I created test directories with and without umlauts and this error seems quite reproducible.
              • B
                bigfatfool
                Hi Guys,
                I have tried everything writen here and I still suffer the problems of many others... nothing happens when I try to import point?!
                I am using windows 7 x86, sketchup 7 latest version... please help cos my head now hurts...
                Cheers,
                Nic
                  Open the Ruby Console before you try to import and post back any error.
                    This is a limitation of the Ruby version that SketchUp ships with. On PC, SketchUp Ruby can not handle any files or folders with non-ASCII characters. The only workaround is for the user to ensure the file and path contains only ASCII characters.
                    • Didier BurD
                      Didier Bur
                      I'm just about to release a new version with some improvements, but thomthom is right: avoid local characters in pathes.
                      Regards,
                      DB
                        johnpa
                        I have gotten cloud to work for me in the past. I even wrote a tutorial to use to teach landscape architecture students how to create a surface from data they gather in the field. But alas it doesn't want to work for me now.
                        I have downloaded Didier's latest version (Cloud67) and installed it. The first menu sees the file and then I click on the origin to create the surface. Nothing happens after that. The Ruby console reports the following error:
                        Error: #<TypeError: nil can't be coerced into Float>
                        (eval):1587:in *' (eval):1587:in draw_geometry'
                        (eval):1584:in each' (eval):1584:in draw_geometry'
                        (eval):1465:in `onLButtonUp'
                        (eval):1584
                        Any help would be really appreciated.
                        JP
                        • Didier BurD
                          Didier Bur
                          Hi John,
                          Cloud67 isn't the latest version, here you can try with 71:
                          http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=678
                          Tell me if it works.
                          Regards,
                          DB
                            johnpa
                            Didier,
                            Thanks, you have come through for me again. Cloud71 works like a champ.
                            I just read through the revised documentation. Nice job. I appreciate how much time it takes to write something like that.
                            Regards,
                            JP
                            • F
                              foudegrat
                              Hello
                              I'm french so excuse my poor english
                              I just instal the last version of Cloud ( cloud_v8b.rbs) with SU8
                              when I try with the example file, it works perfectly but when i try with a personnal file, it doesn't work at all
                              my file is a carrect scv file with ";" for separation, but after the choose of the ile in the windows, nothing appends.
                              9 don't understand the reasons of this bug
                              can you help me?
                              tahnks a lot
                              • Didier BurD
                                Didier Bur
                                @foydegrat: envoies-moi le fichier, c'est plus simple, sinon je ne vois pas comment débugger...
                                DB
                                • F
                                  foudegrat
                                  Voila le fichier
                                  en français c'est beaucoup mieux.
                                  Merci de ton aide Didier!
                                  • F
                                    foudegrat
                                    Voila le fichier (second essai avec un csv ca passe pas)
                                    MNT_25M.txt
                                    • Didier BurD
                                      Didier Bur
                                      Hi foudegrat,
                                      Here is the triangulated MNT (in centimeters) done with cloud_v8.
                                      CSV file is OK, no problem when importing. Don't know why it bugged on your side 😒
                                      I suggest you should use the latest version of cloud: http://rhin.crai.archi.fr/rld/plugin_details.php?id=777 if you have SU8 or http://rhin.crai.archi.fr/rld/plugin_details.php?id=678 if you have SU7.
                                      Regards,
                                      Mnt_25m.zip
                                      DB
                                      • F
                                        foudegrat
                                        Thanks a lot
                                        I have the good plugin, I install it 3 days ago..
                                        Mystery
                                        • 3 / 3
