    [Plugin] Cloud.rb for SU6
    54 Posts 18 Posters 50.3k Views 18 Watching
      SAnderka
      @johnpa said:
      Take a look at this post and download the revised script and you should be good to go. The link to the script is in the post at the top of the thread.
      http://forums.sketchucation.com/viewtopic.php?f=323&t=15807&p=209535&hilit=cloud#p209535
      JP
      Awesome, thanks!
      There is one interesting thing: The plugin won't work on my PC if i copy the examples.dat on my desktop. If I copy it anywhere else, it works just fine, but locating it on the desktop just reproduces the "nothing happens" error it reported above...
      EDIT: Some further testing revealed that the plugin can't handle umlauts in directory names (my user account contains a German umlaut). I created test directories with and without umlauts and this error seems quite reproducible.
        bigfatfool
        Hi Guys,
        I have tried everything writen here and I still suffer the problems of many others... nothing happens when I try to import point?!
        I am using windows 7 x86, sketchup 7 latest version... please help cos my head now hurts...
        Cheers,
        Nic
          Open the Ruby Console before you try to import and post back any error.
            This is a limitation of the Ruby version that SketchUp ships with. On PC, SketchUp Ruby can not handle any files or folders with non-ASCII characters. The only workaround is for the user to ensure the file and path contains only ASCII characters.
            • Didier BurD Offline
              Didier Bur
              I'm just about to release a new version with some improvements, but thomthom is right: avoid local characters in pathes.
              Regards,
              DB
                johnpa
                I have gotten cloud to work for me in the past. I even wrote a tutorial to use to teach landscape architecture students how to create a surface from data they gather in the field. But alas it doesn't want to work for me now.
                I have downloaded Didier's latest version (Cloud67) and installed it. The first menu sees the file and then I click on the origin to create the surface. Nothing happens after that. The Ruby console reports the following error:
                Error: #<TypeError: nil can't be coerced into Float>
                (eval):1587:in *' (eval):1587:in draw_geometry'
                (eval):1584:in each' (eval):1584:in draw_geometry'
                (eval):1465:in `onLButtonUp'
                (eval):1584
                Any help would be really appreciated.
                JP
                  Didier Bur
                  Hi John,
                  Cloud67 isn't the latest version, here you can try with 71:
                  http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=678
                  Tell me if it works.
                  Regards,
                  DB
                    johnpa
                    Didier,
                    Thanks, you have come through for me again. Cloud71 works like a champ.
                    I just read through the revised documentation. Nice job. I appreciate how much time it takes to write something like that.
                    Regards,
                    JP
                    • F Offline
                      foudegrat
                      Hello
                      I'm french so excuse my poor english
                      I just instal the last version of Cloud ( cloud_v8b.rbs) with SU8
                      when I try with the example file, it works perfectly but when i try with a personnal file, it doesn't work at all
                      my file is a carrect scv file with ";" for separation, but after the choose of the ile in the windows, nothing appends.
                      9 don't understand the reasons of this bug
                      can you help me?
                      tahnks a lot
                        Didier Bur
                        @foydegrat: envoies-moi le fichier, c'est plus simple, sinon je ne vois pas comment débugger...
                        DB
                        • F Offline
                          foudegrat
                          Voila le fichier
                          en français c'est beaucoup mieux.
                          Merci de ton aide Didier!
                          • F Offline
                            foudegrat
                            Voila le fichier (second essai avec un csv ca passe pas)
                            MNT_25M.txt
                              Didier Bur
                              Hi foudegrat,
                              Here is the triangulated MNT (in centimeters) done with cloud_v8.
                              CSV file is OK, no problem when importing. Don't know why it bugged on your side 😒
                              I suggest you should use the latest version of cloud: http://rhin.crai.archi.fr/rld/plugin_details.php?id=777 if you have SU8 or http://rhin.crai.archi.fr/rld/plugin_details.php?id=678 if you have SU7.
                              Regards,
                              Mnt_25m.zip
                              DB
                              • F Offline
                                foudegrat
                                Thanks a lot
                                I have the good plugin, I install it 3 days ago..
                                Mystery
                                • 3 / 3
