PC For Rendering - Suggestions?
Looking to buy a new PC for Sketchup and Vray. I will primarily use it for rendering. Any suggestions on the specs that I should be looking for for a descent set up?
Does a good graphics card make a difference?
What should i be looking for (in terms of features) that would help with render times?Thanks
Hi, I am not using Vray though, but try to give some hints:
1st: better ask this question in the Vray subforum here on SCF
2nd: take your time to research and evaluate, You won't get lasting high quality, low cost and fast rendering at the same
3rd: the number of processors is important for rendertimes - the more cores, the faster
4th: take a look at how GPU-rendering is developing atm, If you want what VrayRT can do, get one or more of the best graphics cards...hope this can give a start for orientation - good luck!
Does a good graphics card make a difference?Not with VfSU. Pure raw CPU power.
I think right now getting the best i7 you can afford is probably most crucial. They scale very well for single processor operations like SU's OpenGl viewport but they also have 4 hyperthreaded cores perfect for rendering and from what I hear can be overclocked very well. Like Thomthom said, the new VrayRT engine that uses your GPU won't work in SU, so don't worry too much about your graphics card. A decent gaming card will do (make sure it's nVidia though as ATI and SU don't play nice).
-Brodie
I recommend....
CASE: Raidmax Monster All Aluminum Gaming Case with Advance Heat Management
DVD: 24X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive
CPU: Intel
Core
i7-950 3.06 GHz 8M Intel Smart Cache LGA1366FAN: NZXT Liquid Cooling System 120MM Radiator & Fan (Enhanced Cooling Performance + Extreme Silent at 20dBA)
HDD: 1TB SATA-II 3.0Gb/s 16MB Cache 7200RPM HD
MEMORY: 12GB (4GBx3) DDR3/1600MHz Triple Channel Memory Module Corsair
MOTHERBOARD: Asus P6T SE Intel X58 Chipset CrossFireX Mainboard Triple-Channel DDR3/1600 SATA RAID w/ eSATA,GbLAN,USB2.0,IEEE1394a,&7.1Audio
POWERSUPPLY: 700 Watts - Standard Case Power Supply
SERVICE: STANDARD WARRANTY: 3-YEAR LIMITED WARRANTY PLUS LIFE-TIME TECHNICAL SUPPORT
SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
Approx $1000
For rendering? Your render engine got sound effects? I want too!
That's for watching Netflix while rendering...c'mon get with the program.
Damn, Solo:
If you touch it, you'll fry
Solo, that's a great setup for $1000! Do you have any recommendations on monitors?
-Brodie
http://www.walmart.com/ip/Vizio-E420VO/13904834
Yup, use HDMI to DVI and you got yourself a huge high def screen.
Ha, I've always wanted to try that at home but I've been too lazy to take the computer to the tv or vice versa.
It reminds me of a photo I found on stumbleupon and can't seem to find again. It was of a bunch of cubicles in an office, one of which had a 42" tv in place of a monitor. The caption said that it was a rotating monthly prize for the best salesman or something. It lasted a month and 3 days as the second person to get the honor said it was burning their eyes to have to stare at the 42" screen from about 2' away!
-Brodie
@solo said:
I recommend....
CPU: Intel
Core
Approx $1000
Pete, do you have a link for that setup, or is it build-it-yourself deal?
Sure, but promise to mention me (Pete Stoppel) so I can squeeze them for a deal on my next rig.
http://www.cyberpowerpc.com/system/CyberPower_X58_Configurator/
I get all my rigs from these guys, great machines, well built.
Thanks for that link Pete, those are amazing prices. If I gt one from there, I'll definitely tell them you sent me
I really want a laptop though, preferably one that will work with Thea...any recommendations? Cyber Power's laptops seem extraordinary pricey...
Yeah, cyberpower is great for monster desktops, not lappy's.
Tried http://www.newegg ? http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100006740+600003982+600004804&QksAutoSuggestion=&ShowDeactivatedMark=False&Configurator=&IsNodeId=1&Subcategory=32&description=&Ntk=&CFG=&SpeTabStoreType=&srchInDesc=
I'll try NewEgg...thanks for the help
@solo said:
Approx $1000
why spend only a thousand when you could easily configure one of these bad boys to well over $6g?
6 g's for only 12 cores, hmm, I'd rather network 6 of those machines together and get 48 render threads...zoom, zoom, zoom.
ha, yeah.. i'm used to apple tax but man, that thing is crazy priced.. borderline ridiculous
If you can wait a couple months it might be worth doing so to get the upcoming intel processor (Sandy Bridge) which looks considerably faster than current gen.
From the referenced article:
Clock for clock however, Sandy Bridge seems to offer a 10% increase in performance. Keep in mind that this analysis was done without a functional turbo mode, so the shipping Sandy Bridge CPUs should be even quicker. I'd estimate you can add another 3 - 7% to these numbers for the final chips.
As for the graphics card (which I don't know how you can overlook a graphics card after you've seen GPU rendering examples -- including the free smallluxgpu) I would highly recommend the GTX 460 (around US $200/$230 for 796MB and 1000MB flavors) which is fast and relatively low noise/power.
At least... this is the route I'm taking (soon).
