    Open ended model
    4 Posts 3 Posters 438 Views 3 Watching
      Photon713
      Trying to determine how to close what is now an open ended model. Visually it looks like one end of a 3D box with one end open. The model was created from extrudes and follow-me's. I've tried welding all line segments without success. I've tried connecting top and bottom edges with vertical lines with limited success. Suggestions welcomed. Thanks
      • BoxB Offline
        Your best bet is to attach the model so someone can see what the problem is.
        But first thing that springs to mind, you probably have a group or component and are trying to add to it without being in edit mode.
        Or the surface you are trying to close isn't flat/coplaner.
          We need an example...
          You probably need to weld four sets of perimeter edges into curves then use EEbyRails on them and make a 3D meshed surface to close the end ? ...
            Photon713
            Thanks, everyone...
            I was using a profile for the front and back of the model.
            For some reason the width of one of the profiles was slightly shorter. I suspect I inadvertently moved an edge while I was moving it into position as an import and sliding it into place. I couldn't see the break until I scaled it up. Thanks everyone.
