    Extract Material thumbnail?
    17 Posts 3 Posters 1.9k Views 3 Watching
      But isn't that thumbnails for .skp files? Like Sketchup.save_thumbnail http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/sketchup.html#save_thumbnail
        The think that SDK's ISkpThumbnailProvider code is applicable to any object supporting a thumbnails - like Components and Materials...Capture.PNG
          And this C++ voodoo can be used at run-time?
          • AdamBA
            AdamB
            Just open the file from Ruby and rip out what you want, whats the problem?
              I think you'd need to make an add-on that loads at startup that provides extra methods like the Exporters do like Skp2Acad.dll [presumably something else on a Mac!]- in this case say export(material.thumbnail,"filepath") ❓
              Not sure - it's a bit outside my remit............
              You can also find the material's texture inside the SKP file's data but then getting it's thumbnail and the 'bits' is beyond me... 😞
                But how - how do we find the particular material, then its texture and then its thumbnail within the mess of SKP data... ❓ 😕
                  Because that would require the user to save the model before the script would be able to extract the thumbnails.
                  As mentioned - I'm trying to make a replacement for the material browser - so I need to get the material thumbnails at run time from the open model.
                    Also - material thumbnails doesn't appear to be stored in the .skp file... 😞
                      The material thumbnails are stored in the .SKM files [which is actually '.ZIP' files].
                      You can export a material's texture's image-file quite easily using existing API methods... and use that as your image... OR extract the thumbnail from the .SKM file as if it were a 'zip' using Ruby 'zip' methods'... 😕
                        @tig said:
                        You can export the material's texture's image-file quite easily using existing API methods
                        Original size - which might be huge. Not ideal for a material browser which would then load lots of full size images and only display it at a fraction of its size.
                        @tig said:
                        OR extract the thumbnail from the file as if it were a 'zip' using ruby 'zip' methods'...
                        But there isn't a way to get in-model materials exported as .skm via Ruby, is it? ❓
                          If you get a 'large' image there are Ruby tools to down-size it into a thumbnail ???
                          http://rmagick.rubyforge.org/
                          http://snippets.dzone.com/posts/show/3621
                          http://oldwiki.rubyonrails.org/rails/pages/HowtoCreateThumbnailImages
                          etc etc............
