    Extract Material thumbnail?
    17 Posts 3 Posters 1.4k Views 3 Watching
      I find a method to extract thumbnails for components, but is there none for Materials? (please don't tell me No - I'll have a fit if you do)
        No. 😳
        BUT you know the materials color and you can export the model's material's texture [if any] so you can easily make a temporary copyin the Temp folder ? Something like this...
        ### 'material' is the material in point...
        ### and
        filename=material.name +".jpg" ### etc ??? you can get the original image name/path too ???
        tdir=ENV["TEMP"]
        tdir=ENV["TMPDIR"]if not tdir ### it's a Mac
        tdir=tdir.tr("\\","/")+"/" ### if needed
        filepath=tdir+filename
        group=Sketchup.active_model.active_entities.add_group
        group.material=material
        tw=Sketchup.create_texture_writer
        tw.load(group)
        tw.write(group,filepath)
        ### etc...
        External skm's are actually zip files so you can extract the image from those if you have some zip manipulation ruby methods etc [I recall TBD has one of those ?].......
          πŸ‘Š Another project stomped due to lacking API. X_x grrr...
          The thing is- I don't want to extract the full texture. They can be very large.
          I need to get the thumbnail for my recreation of the Material browser. I don't want to extract 50 large textures and send it to the webdialog. That would just slow it right down - plus take up extra disk space.
          The thumbnails is what I need. They are small enough so you can pass them directly to the webdialog without saving them to disk - using data URIs which IE8 finally support, provided they are under 32KB.
          • AdamBA Offline
            AdamB
            Its stored in "doc_thumbnail.png" in the SKM file.
            But can we see you "throwing a fit" for entertainment value?
              Why yes you may. I can manually get the thumbs from an skm file - but not from Ruby during run time. 😞 So stand by for a fit.
                If you have the SDK you'll see there are methods for getting/saving thumbnails [url]file:///C:/Program%20Files/Google/Google%20SketchUp%207/sdk/SkpReader/documentation/interface_i_skp_thumbnail_provider.html[/url] [path might differ on your PC]
                But you'll then need to compile a C++ applet to give the new method material.thumbnail!
                  But isn't that thumbnails for .skp files? Like Sketchup.save_thumbnail http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/sketchup.html#save_thumbnail
                    The think that SDK's ISkpThumbnailProvider code is applicable to any object supporting a thumbnails - like Components and Materials...Capture.PNG
                      And this C++ voodoo can be used at run-time?
                      • AdamBA Offline
                        AdamB
                        Just open the file from Ruby and rip out what you want, whats the problem?
                          I think you'd need to make an add-on that loads at startup that provides extra methods like the Exporters do like Skp2Acad.dll [presumably something else on a Mac!]- in this case say export(material.thumbnail,"filepath") ❓
                          Not sure - it's a bit outside my remit............
                          You can also find the material's texture inside the SKP file's data but then getting it's thumbnail and the 'bits' is beyond me... 😞
                            But how - how do we find the particular material, then its texture and then its thumbnail within the mess of SKP data... ❓ πŸ˜•
                              Because that would require the user to save the model before the script would be able to extract the thumbnails.
                              As mentioned - I'm trying to make a replacement for the material browser - so I need to get the material thumbnails at run time from the open model.
                                Also - material thumbnails doesn't appear to be stored in the .skp file... 😞
                                  The material thumbnails are stored in the .SKM files [which is actually '.ZIP' files].
                                  You can export a material's texture's image-file quite easily using existing API methods... and use that as your image... OR extract the thumbnail from the .SKM file as if it were a 'zip' using Ruby 'zip' methods'... πŸ˜•
                                    @tig said:
                                    You can export the material's texture's image-file quite easily using existing API methods
                                    Original size - which might be huge. Not ideal for a material browser which would then load lots of full size images and only display it at a fraction of its size.
                                    @tig said:
                                    OR extract the thumbnail from the file as if it were a 'zip' using ruby 'zip' methods'...
                                    But there isn't a way to get in-model materials exported as .skm via Ruby, is it? ❓
                                      If you get a 'large' image there are Ruby tools to down-size it into a thumbnail ???
                                      http://rmagick.rubyforge.org/
                                      http://snippets.dzone.com/posts/show/3621
                                      http://oldwiki.rubyonrails.org/rails/pages/HowtoCreateThumbnailImages
                                      etc etc............
