    Geosphere?
    15 Posts 6 Posters 1.5k Views 6 Watching
    • T
      tml
      Note that the above results in just a fairly nice approximation, though. (And I don't know if it matches the subdivision used in your example image.) Only for the (not really sphere-like, as they have so few faces) Platonic solids are the vertices in a strict sense evenly distributed, though. See http://www.cgafaq.info/wiki/Evenly_distributed_points_on_sphere and especially http://www.math.niu.edu/~rusin/known-math/95/sphere.faq .
        Approximation is ok. Just just want to take a fixed number of points and distribute them approximately evenly. Doesn't matter if they need to be rounded to a number that fit some geometric restriction.
        Thanks for the links - I'll look into them.
          Excellent - the spiral methods works great for my use! πŸ‘
          • AdamBA
            AdamB
            Its pretty common to subdivide a cube and then project onto a sphere.
            If you want evenly distributed but not a regular mesh, you could use a Hammersley point set.
              Would that give a even-ish distribution?
              Thanks for the pointer - will look it up. πŸ‘
              • david_hD
                david_h
                A sphere with a center (x0,y0,z0) with diameter r
                has all points x,y,z like
                http://upload.wikimedia.org/math/3/3/0/33031c82e871501422b05455c81d2680.png
                with
                http://upload.wikimedia.org/math/e/b/9/eb91f8174391d023015dedf9beb94e5d.png
                http://upload.wikimedia.org/math/9/0/1/9011474548ae3216019a280ff95d25a3.png
                = Latitude
                http://upload.wikimedia.org/math/1/9/6/1964adc54d7dc608fd9f63a46cae422b.png
                = longitude
                That is just how I would do it! πŸ˜’ πŸ’š
                  Me too πŸ˜„
                    Google are really quick to index this site!
                    I did a search for "Hammersley point set sphere" and this thread came up as #3 already. πŸ˜’
                    • mitcorbM
                      mitcorb
                      Not busy enough elsewhere, eh tml?
                      Thank you for your talents, also.
                      • AdamBA
                        AdamB
                        There you go.
                        404 Not Found
                        (forums.sketchucation.com)
