    Geosphere?
    15 Posts 6 Posters 986 Views 6 Watching
      How do you calculate a set of points on a sphere which is evenly distributed from each other?
        Best I can find is: http://en.nicoptere.net/?p=12 - actionscript based on this: http://www.math.niu.edu/~rusin/known-math/96/repulsion
        But I'm not making a whole lot sense out of it. The code doesn't have much commenting...
          A sphere with a center (x0,y0,z0) with diameter r
          has all points x,y,z like
          http://upload.wikimedia.org/math/3/3/0/33031c82e871501422b05455c81d2680.png
          with
          http://upload.wikimedia.org/math/e/b/9/eb91f8174391d023015dedf9beb94e5d.png
          http://upload.wikimedia.org/math/9/0/1/9011474548ae3216019a280ff95d25a3.png
          = Latitude
          http://upload.wikimedia.org/math/1/9/6/1964adc54d7dc608fd9f63a46cae422b.png
          = longitude
            Isn't that a sphere with poles? The points would not be evenly spaced.
            I'm looking to generate the points for the sphere on the right.
              tml
              Start with a octahedron, divide each edge into half and thus each face into four equal smaller triangles, move the new vertices to the desired radius, repeat.
                tml
                Note that the above results in just a fairly nice approximation, though. (And I don't know if it matches the subdivision used in your example image.) Only for the (not really sphere-like, as they have so few faces) Platonic solids are the vertices in a strict sense evenly distributed, though. See http://www.cgafaq.info/wiki/Evenly_distributed_points_on_sphere and especially http://www.math.niu.edu/~rusin/known-math/95/sphere.faq .
                  Approximation is ok. Just just want to take a fixed number of points and distribute them approximately evenly. Doesn't matter if they need to be rounded to a number that fit some geometric restriction.
                  Thanks for the links - I'll look into them.
                    Excellent - the spiral methods works great for my use! 👍
                    • AdamBA Offline
                      AdamB
                      Its pretty common to subdivide a cube and then project onto a sphere.
                      If you want evenly distributed but not a regular mesh, you could use a Hammersley point set.
                        Would that give a even-ish distribution?
                        Thanks for the pointer - will look it up. 👍
                        • david_hD Offline
                          david_h
                          with
                          = Latitude
                          = longitude
                          That is just how I would do it! 😒 💚
                            Me too 😄
                              Google are really quick to index this site!
                              I did a search for "Hammersley point set sphere" and this thread came up as #3 already. 😒
                              • mitcorbM Offline
                                mitcorb
                                Not busy enough elsewhere, eh tml?
                                Thank you for your talents, also.
                                • AdamBA Offline
                                  AdamB
                                  There you go.
                                  http://forums.sketchucation.com/viewtopic.php?f=180&t=30694&p=269864#p269864
