    How would you do this?
    13 Posts 6 Posters 3.5k Views 6 Watching
    • EscapeArtistE Offline
      EscapeArtist
      I'm trying to make a hose along a path. One way to do it is to make the shape, multiply it, and then use bend tools to bend it how I want. But that's very tedious and difficult to do accurately and some geometry starts disappearing. What would be ideal is a "lathe along path" or something, but is there any other way? One of the "-by rails" plugins? Component stringer?
        Does the tube must be "spiraled" or just "cylindric" as the little module shown?
          EscapeArtist
          No twist necessary; in fact preferably not.
          • BoxB Offline
            This was done quickly with Component Stringer.
              EscapeArtist
              That's pretty darn good Ben. I'm hoping for something more contiguous like the hose I bent at the top, I'll be rendering it and want it to look good. Maybe intersecting and using your method will do, but that would mean a lot of cleanup work.
              • BoxB Offline
                I'm sure you can achieve what you want with a little work, I only threw that together.
                If you make the component just like you want and move the axis to the centre of the component it will follow whatever line you want.
                  EscapeArtist
                  Looks good. Will give it a shot.
                  EDIT: Unfortunately I have some tight turns that cause the component ends to leave gaps, if I extend the component to close the gap it protrudes beyond the component wall. Dang.
                    Jim
                    Maybe FredoScale could Bend a straight section well enough?
                    • BoxB Offline
                      You could "make Unique" the ones with gaps and just tweak them a bit, rotate the end to fit the gap.
                        EscapeArtist
                        Thanks for the suggestions everyone. I've mostly given up for now, there's just too much cleanup work involved in stringing components, so I've settled for just a tube along path. Ideally a lathe along path would be great, but it simply doesn't exist for SU.
                        • BoxB Offline
                          If you use components and make a pipe, then bend it using Fredoscale Radial bender you have no cleanup.
                          The components fit together and adjust themselves for the curves.
                          http://i155.photobucket.com/albums/s296/storeben/SU/Pipe.png
                          • Chris FullmerC Offline
                            Have you tried shape bender on it? That should do the trick, though it might take a lot of processing time. And you might have to scale it up if it is creating a lot of small faces.
                            • jeff hammondJ Offline
                              ShapeBender:
