    Google is Listening!
    329 Posts 70 Posters 156.0k Views 70 Watching
    • PixeroP
      Pixero
      @thomthom said:
      Have you been poking around in my hard-drive? ๐Ÿ˜ฎ ๐Ÿ˜‰
      Not your hard-drive...your head. ๐Ÿ˜†
      • V
        Viztecture
        1. support for high poly models, even just better navigation.
        2. better texturing tools, projection is very limited (yeah i know thomthom plugins work but we need more, I'd love to 'paint' textures onto surfaces)
        These two points are my greatest desires also... texture layering and editing through a paint tool within Sketchup would be tremendous... Proper supported UV unwrapping would be enough however... ๐Ÿค“
        http://www.viztecture.mfbiz.com
          Like you do in Photoshop when importing 3d models? Is that what you mean by painting?
          @olishea said:
          1. ability to open SketchUp at whatever reolution you like. So when it starts up you could just type 1024x768 for example. at the moment it opens at 1024 x739.
          Gaieus use a nice utility for that - lets you size any application to a fixed size. Don't remember what it was called now.
          @olishea said:
          1. multi-core support. How come it doesn't have this already? โ“
          Also not something that's a magic bullet or something one just switch to "on". Multi-core is difficult and in many cases not applicable. This is what John meant by when he'd like to see people ask for what they'd like to see as result - not the technical implementation itself. This request falls inline with #1 - better performance.
          @olishea said:
          1. all plugins in one place.....a website that is. Like a list on the google wesbite that will link you to all the plugins available.
          Would love to see a repository where one could upload plugins and be able to download from SU. And SU'd notify about updates. Like the package manager in Linux distributions.
          • N
            notareal
            ...but still, what are you going to gain from more memory?
            Maybe not important for everyone, but one simply reason for me, going to 64-bit SU would allow 64-bit renderer work in context of SU. It's already possible to create a SU scene that will not render with SU integrated 32-bit renderer, because of memory restrictions.
            • N
              notareal
              @adamb said:
              @thomthom said:
              @adamb said:
              Like Jeff Hammond, I struggle to understand what workflow using SU requires 2 GB of memory. I'd say your workflow needs looking at.
              When you export really large 2d exports that memory usage easily run up to that point - nothing to do with the workflow. But that's about the only area where SU itself run into the memory issue. Mostly it's when using render engines that run inside SU's process.
              I don't understand. 10000 pixel * 10000 pixel * RGBA is 400MBytes. You're doing images larger than this? Mad.
              EDIT: OK perhaps not Mad. But surprising. ๐Ÿ˜„
              Memory use can be high with relight, displacement and so... not to forget full spectral engines.
              • K
                Khai
                @jbacus said:
                @khai said:
                I make Poser content as a base, but which it being OBJ can be loaded into any application that supports OBJ. eg Maya, Lightwave, Cinema4D, Max, Hexagon, Carrara, Vue, Softimage, Blender, Wings3D, .... the list goes on. of those apps only Softimage, Max.. I think Maya and Cinema read DAE. and even then it's not guaranteed as supported as OBJ. infact for UVmapping work the 2 major UVapps UVlayout and UVmapper only support OBJ!
                but from your answers I'm not holding out much hope of getting the point across.
                I think I get your point just fine. So what you want to do is make models in Poser that can be loaded into a SketchUp scene? According to this page (http://poser.smithmicro.com/poserpro.html) Poser Pro 2010 supports COLLADA import/export.
                edit oh forget it.
                my question orginally was about the logic of the choice. now it's just lost.
                I get it. you prefer Collada even tho it is a poorly supported format at this time.
                • V
                  Viztecture
                  Yeah i think so, i havent used CS5 yet.. I was thinking more like zbrush esp for blending 2 textures
                  • L
                    l.frisken
                    To the guy asking for sketchup -> luxrender... I'll continue work on it after finish my last high school exams (ever, yeah!) ๐Ÿ˜„
                    • olisheaO
                      olishea
                      thomthom i mean being able to paint seamless textures onto organic shapes, don't know the exact term for this.....where you can unfold the shape and apply UV map. It would be cool to have full control over textures. Not just "get what you're given"
                      oli
                        He was talking about SU's 2D export.
                        • N
                          notareal
                          Woops... miss read to 3D. ๐Ÿ˜ณ
                          • olisheaO
                            olishea
                            yeah i think so, i havent used CS5 yet.. I was thinking more like zbrush esp for blending 2 textures
                            yeah thats what i meant by "paint". you could blend several seamless textures by using a "texture brush tool"
                            could change radius, opacity etc....but maybe this is wishing for too much. But this could be possible within SU.
                            oli
                              Aerilius
                              Does the Ruby API allow to set a color value to a pixel of a texture? Or to reload a texture image very fast? Would it be theoretically possible with Ruby + ImageMagick or would we need to wait for the SketchUp team?
                              Another thing that I would like (maybe easier as painting) is deforming UV coordinates on multiple/curved surfaces with a smooth tool. This would allow to project your texture with a simple spherical projection and if you don't like the result, you just drag and deform the texture until it fits.
                                No - no read or write to image data. ๐Ÿ˜ž
                                Reloading texture via the API is no faster than what you do in the UI.
                                I'm not fully able to envision what you describe. This "Smooth" tool?
                                Are you talking about a spherical mapping tool? (Where you stretch and squash the sphere?)
                                  Is there an app that already has such a feature? I'm curious of how it'd work.
                                    Aerilius
                                    Sorry, I meant something similar to smooth selection in vertex tools, that you can use to move/rotate/deform the texture coordinates.
                                    http://smashingpoint.com/wp-content/uploads/2008/08/14.jpg
                                    • N
                                      notareal
                                      Don't say that they have this, but I'd would first look on zbrush or sculptris.
                                        I see how it works for brushes for 3d modelling - but I'm not able to see how it'd be used for UV co-ordinates. Can you illustrate it some way?
                                        • PixeroP
                                          Pixero
                                          Maybe like how Photoshop has "liquify" where you distort a grid that distorts the coordinates?
                                          http://www.photokaboom.com/images/Photoshop_Elements/retouching/liquify_filter/grid_for_Liquify_tool_experimenting_distorted_resampled.jpg
                                            Aerilius
                                            Sorry, that I don't know how to explain it technically, or its feasibility. I think I thought already about it and can imagine how it works on a triangle mesh with 3 texture coordinates, but there is always the forth coordinate.
                                            Maybe it's "innovative"
                                            • 16
                                            • 17
                                            • 4 / 17
