    New Monitor, need advise
    13 Posts 5 Posters 711 Views 5 Watching
    • O Offline
      Otis
      Just switched from a 15" monitor to a new 24" monitor. Way more room to work, which is great. However, all my lines are not as crisp as they were before. I assume because of the increased size that the squiggly lines appear more pronounced. I have either set profiles to one, or left it unchecked, but it's still to squiggly for my taste. Are there other things I could try to get a more even line ?
      • soloS Offline
        Otis, is the new screen a monitor or an LCD TV?
        What GPU/video card do you have?
        How are you connected, with VGA, DVI or HDMI?
        • O Offline
          Otis
          It's a monitor by AOC. The vidio card is a GeForce 9500 GT. I think it's hooked up vga. It came with a HDMI cord also but I didn't see a place to plug it in to my computer. I just hooked it to the old cable that went with the old moniter.
          • soloS Offline
            I would suggest using the HDMI cable as that's digital and VGA is analogue (vast difference in image quality) So, your monitor has HDMI but your video card does not?
            I thought all the 9 series Nvidia cards have HDMI outs, I have an old computer with a 8800gtx which has 2 HDMI outs for dual monitors.
            • O Offline
              Otis
              Thanks Solo, just got back and pulled out the computer for a second look and it does indeed have a HDMI port. It does make a difference, much crisper now. I was toying with the idea of using the old monitor as a second, but don't know if I can do it or not. I still have the old vga port, could I just hook it up as well to the old monitor,or is there more to such a configuration?
              • honoluludesktopH Offline
                honoluludesktop
                Sorry to suggest something so simple, but did you right click on a blank part of the desktop screen and select properties > settings then adjust for a higher screen resolution, then properties > appearance and adjust font size.
                • O Offline
                  Otis
                  Yes, it was the first thing I did when I fired up the new monitor.As I said in the last post, the switch to the HDMI cable proved to be the ticket.
                    honoluludesktop
                    Didn't realize that a HDMI connection would make a difference regarding jaggies. Wow, when I go to work tomorrow, I'll have to see if my 24" monitor has a HDMI port.
                    • BoxB Offline
                      Most video cards are able to run two monitors, but more than two and you need another card.
                      Just plug in the VGA and the HDMI and go to display/settings and enable the second monitor.
                      There is a program (not Free but with a free trial) called VT Multi Display with works very well when you have a multiple monitor set up.
                      http://www.villagetronic.com/vtmd/index.html
                      Even with a laptop it is possible to use two large screens, you simply disable the laptop screen.
                      • O Offline
                        Otis
                        Thanks Box, I'll give it a go.
                          MartinRinehart
                          You are very smart to have gotten that monitor. Easy to love, no?
                          • O Offline
                            Otis
                            Yup, no doubt the best thing I've done in quite awhile. Didn't realize how cheap they had gotten.Paid a little over $150 US. Easy on the eyes and wallet!
                              honoluludesktop
                              $150.00 for a 24" monitor?-0 That's a fourth of what I paid for mine. Are 30" under $1,000.00 now?
