    V-Ray Rendering Problem
    renderpluginsextensions
    2 Posts 2 Posters 650 Views 2 Watching
      Richoss
      I'm not sure if this is in the right section, but if it isn't, can a moderator move it to the correct place.
      Okay so I have a problem when I go to render my house model. Instead of trying to explain, I will show what happens.
      The first one is a print screen of the model, the second picture is a render using V-Ray.
      So you can see when I go to render, the colour of the materials revert back to the orginal colour. I changed the colour of the materials in sketchup to achieve what I wanted.
      How do I overcome this? I'm fairly new to V-Ray and rendering, and this was my second model attempt.
      Thanks guys
        VfSU doesn't support textures modified by SU. You must edit the texture in a image editor.
        ps. it helps if you post your VfSU version number when asking questions. Some versions behave differently from each other.
