    [Q] Is there a spiral along path ruby?
    23 Posts 6 Posters 2.2k Views 6 Watching
    • utilerU Offline
      utiler
      ...you got too much time on your hands then Jeff. 😉
      nice though.
      Just Curious...
      • jeff hammondJ Offline
        nice though.
        ha.. not really.. that cut into my sleep time!
          d12dozr
          That's neat Jeff, how did you do it? lotsa fredoscale?
          http://goo.gl/f7ooYh
            d12dozr
            Thanks. ☀
            What does Component Stringer do?
              Here's the Down and Dirty tutorial..
              Ell_Down-N-Dirty_tut.skp
              component stringer will repeat a component along a path.. you can also set it to rotate that component along the path.
                no fredoscale..
                BezierSpline (v1.4)
                Component Stringer
                Follow Me
                (+ a few others.. see tutorial a couple posts down)
                  d12dozr
                  Thanks again! Now I'm off to get some sleep...
                    Susy
                    8 minutes: With the same procedure as I said initially...
                    Although not is it what the moderator need for its job
                    Ell_Down-N-Dirty_tut (8 Minutes).skp
                      oh yeah, didn't think of that before.. i'm assuming you used shapebender..
                      but hey, you used my L 😄..
                      that's the hardest part
                      • charly2008C Offline
                        charly2008
                        Hi Solo,
                        Is that what you want to do? I used in this example GROW and CURVILOFT. With GROW you can manipulate almost all parameters. Other options are the diameter of the circle and the angle of the edge. The process is very easy.
                        Charly
                        Spirale.skp
                          charly2008
                          GROW and CURVILOFT are a good combination for many profile designs.
                          • 2 / 2
