    [Q] Is there a spiral along path ruby?
    23 Posts 6 Posters 2.5k Views 6 Watching
    • soloS
      Easy now Susy, before getting yer nickers in a twist (or spiral) understand what I need.
      I need to be able to spiral or twist a ribbon around many shapes, some bends are 15%, 45% some are 90%, I need it to be precise, so bending may not work, I also need it to be continuous, so one bend at a time and joining will also not do.
      Oh, I'm a moderator on the forum and not the teacher/guru (there is lot's I do not know), I help where I can, and keep it clean from spammers and trolls.
      Like many users I download and use only the plug ins that I need, when I need them, they sometimes only get used once or twice as I need them and more than often after a while I forget about them and have to try and remember what they are called in order to find them in my shopping list drop down menu.
      In an instance like this plug-in question, I have never needed this before and know there have been many spiral and twist plug-ins, that's why I asked the question, if I knew for a fact that one did not exist I'd make a request, similarly if I knew it did exist I would not ask.
      • jeff hammondJ
        [i still have no clue about what you're needing to draw]
        ๐Ÿ˜†
        • utilerU
          utiler
          Deep breathing Pete; concentrate on the patterns....
          Think the night before Basecamp. Lots of ๐Ÿ˜ and ๐ŸŽ‰ and few ๐Ÿ˜† and ๐Ÿคฃ ....
          Just Curious...
          • soloS
            Okay...
            It's an LED light ribbon that needs to twist in the shape of a company name, the writing is cursive and will be the center piece of it's exhibit display, I cannot discuss more details as I have the usual non disclosure contract.
            The problem is I need to match their font precisely, so doing bend for bend will not work.
            • soloS
              I was hoping to bring in a DWG file with the name, weld it and hit 'follow me with a twist' button and viola!! done. ๐Ÿ˜„
                Susy
                ok...
                • jeff hammondJ
                  i was drawing this while you replied (which is what d12dozr was saying) but i think it might actually be what you're talking about except you'd like the orange ribbon to be a much tighter spin and it wraps around letters?.. if so, i don't think there's a one click method for that..
                  • jeff hammondJ
                    i'm sorta sure this isn't what you're after but i got stuck on the idea of it and had to figure it out.. let's hope this isn't what you're trying to draw -or- someone has an easier/faster method than mine.. this took over an hour ๐Ÿ˜†
                    Ell_3.skp
                    • utilerU
                      utiler
                      ...you got too much time on your hands then Jeff. ๐Ÿ˜‰
                      nice though.
                      Just Curious...
                      • jeff hammondJ
                        nice though.
                        ha.. not really.. that cut into my sleep time!
                          d12dozr
                          That's neat Jeff, how did you do it? lotsa fredoscale?
                          http://goo.gl/f7ooYh
                            d12dozr
                            Thanks. โ˜€
                            What does Component Stringer do?
                            • jeff hammondJ
                              Here's the Down and Dirty tutorial..
                              Ell_Down-N-Dirty_tut.skp
                              component stringer will repeat a component along a path.. you can also set it to rotate that component along the path.
                              • jeff hammondJ
                                no fredoscale..
                                BezierSpline (v1.4)
                                Component Stringer
                                Follow Me
                                (+ a few others.. see tutorial a couple posts down)
                                  d12dozr
                                  Thanks again! Now I'm off to get some sleep...
                                    Susy
                                    8 minutes: With the same procedure as I said initially...
                                    Although not is it what the moderator need for its job
                                    Ell_Down-N-Dirty_tut (8 Minutes).skp
                                    • jeff hammondJ
                                      oh yeah, didn't think of that before.. i'm assuming you used shapebender..
                                      but hey, you used my L ๐Ÿ˜„..
                                      that's the hardest part
                                      • charly2008C
                                        charly2008
                                        Hi Solo,
                                        Is that what you want to do? I used in this example GROW and CURVILOFT. With GROW you can manipulate almost all parameters. Other options are the diameter of the circle and the angle of the edge. The process is very easy.
                                        Charly
                                        Spirale.skp
                                        • charly2008C
                                          charly2008
                                          GROW and CURVILOFT are a good combination for many profile designs.
