    [Q] Is there a spiral along path ruby?
    23 Posts 6 Posters 2.5k Views 6 Watching
    • jeff hammondJ
      i was drawing this while you replied (which is what d12dozr was saying) but i think it might actually be what you're talking about except you'd like the orange ribbon to be a much tighter spin and it wraps around letters?.. if so, i don't think there's a one click method for that..
      • jeff hammondJ
        i'm sorta sure this isn't what you're after but i got stuck on the idea of it and had to figure it out.. let's hope this isn't what you're trying to draw -or- someone has an easier/faster method than mine.. this took over an hour 😆
        Ell_3.skp
        • utilerU
          utiler
          ...you got too much time on your hands then Jeff. 😉
          nice though.
          Just Curious...
          • jeff hammondJ
            nice though.
            ha.. not really.. that cut into my sleep time!
              d12dozr
              That's neat Jeff, how did you do it? lotsa fredoscale?
              http://goo.gl/f7ooYh
                d12dozr
                Thanks. ☀
                What does Component Stringer do?
                • jeff hammondJ
                  Here's the Down and Dirty tutorial..
                  Ell_Down-N-Dirty_tut.skp
                  component stringer will repeat a component along a path.. you can also set it to rotate that component along the path.
                  • jeff hammondJ
                    no fredoscale..
                    BezierSpline (v1.4)
                    Component Stringer
                    Follow Me
                    (+ a few others.. see tutorial a couple posts down)
                      d12dozr
                      Thanks again! Now I'm off to get some sleep...
                        Susy
                        8 minutes: With the same procedure as I said initially...
                        Although not is it what the moderator need for its job
                        Ell_Down-N-Dirty_tut (8 Minutes).skp
                        • jeff hammondJ
                          oh yeah, didn't think of that before.. i'm assuming you used shapebender..
                          but hey, you used my L 😄..
                          that's the hardest part
                          • charly2008C
                            charly2008
                            Hi Solo,
                            Is that what you want to do? I used in this example GROW and CURVILOFT. With GROW you can manipulate almost all parameters. Other options are the diameter of the circle and the angle of the edge. The process is very easy.
                            Charly
                            Spirale.skp
                            • charly2008C
                              charly2008
                              GROW and CURVILOFT are a good combination for many profile designs.
