    [SOLVED]set standard view
    15 Posts 4 Posters 1.4k Views 4 Watching
      Jim
      Not 100% sure, but...
      What is the Scene transition time set to? Either set it to 0, or wait for the Scene animation to finish before writing the image.
      • P
        Pout
        ThomThom:
        no, but i'll give it a shot
        Jim:
        scene transitions are off
          @pout said:
          ThomThom:
          No - I was thinking that might be why it didn't work.
          Maybe you can use view.refresh ?
            Jim
            Ah, there are no scenes, so no scene tranistions.
            Oh, and even simpler: πŸ˜‰
            standardviews = %w(viewTop; viewBottom; viewFront; viewBack; viewRight; viewLeft viewIso;)
            standardviews.each do |view|
              Sketchup.send_action(view)
              # write image
            • P
              Pout
              Thx Jim for the code update
              ThomThom,
              I've tried just to see if there was any diff. and there is none.
              I also already tried to do active_view.refresh after each view switch but that doesn't help either.
              In the API this is the explanation on send_action:
              The send_action method sends a message to the message queue to perform some action asynchronously.
              I don't know if this could have something to do with it
              Btw did you try the code?
              Extra info, if you switch pages 'scenes) in the same loop all goes well.
                Hm...
                Tried setting the camera object itself instead of issuing the SU commands?
                • P
                  Pout
                  I was thinking about that.
                  But I need the standard views attributes for that so i can use them in a camera definition.
                  I have not yet found a way to adress these standard views. (or i'm looking over it completely)
                    Attributes? Camera definitions?
                      You mean how to set the camera vectors?
                      I'd think just setting the camera to match X_AXIS, YAXIS and Z_AXIS should be enough... ?
                      • P
                        Pout
                        yes to 'copy' the standard cameras it would be great to be able to copy the eye, target and up of the standard cameras into new cameras so i can use those.
                        fact is i can't itterate over those standard cameras as shown above and i need the specific values of eye and target otherwise i need to calculate the center of the bounding box of all elements of the model to specify the eye and target.
                        At the other hand, maybe i'm lacking any sense today (you wouldn't be the first to say that today πŸ˜„)
                          And once you set the camera eye to target vector to suit an AXIS vector you need to use Sketchup.send_action("viewZoomExtents:") to see everything ???
                            The native standard view buttons doesn't zoom extent - but if that is what you want - then eye and target does not matter.
                            direction = Z_AXIS.reverse Sketchup.active_model.active_view.camera.set( ORIGIN, direction, direction.axes.y) Sketchup.active_model.active_view.zoom_extents
                            • P
                              Pout
                              Overview of the code for each standard view (informative)
                              Top
                              Bottom
                              direction = Z_AXIS
                              Front
                              direction = Y_AXIS
                              Back
                              direction = Y_AXIS.reverse
                              Left
                              direction=X_AXIS
                              Right
                              direction=X_AXIS.reverse
                              Iso
                              direction=Geom;;Vector3d.new -0.666667, 0.666667, -0.333333
                              This emulates the standard cameras, combined with zoom extents.
                              Credits to ThomThom!
