    [SOLVED]set standard view
    15 Posts 4 Posters 1.5k Views 4 Watching
    • P
      Pout
      I know it is possible to use Sketchup.send_action("viewIso:") to set the active_view to one of the standard views.
      The problem is, when this is used in a loop like this all images return equal:
      standardviews=['SV_Top','SV_Bottom','SV_Front','SV_Back','SV_Left','SV_Right','SV_Iso']
      standardviews.each{|view|
      if view=='SV_Top'
      	Sketchup.send_action("viewTop;")
      elsif view=='SV_Bottom'
      	Sketchup.send_action("viewBottom;")
      elsif view=='SV_Front'
      	Sketchup.send_action("viewFront;")
      elsif view=='SV_Back'
      	Sketchup.send_action("viewBack;")
      elsif view=='SV_Left'
      	Sketchup.send_action("viewLeft;")
      elsif view=='SV_Right'
      	Sketchup.send_action("viewRight;")
      elsif view=='SV_Iso'
      	Sketchup.send_action("viewIso;")
      x = Sketchup.active_model.active_view
      path="c;\\"+Sketchup.active_model.title
      imagename = path+view.to_s+".jpg"
      Sketchup.set_status_text("Writing #{imagename}")
      x.write_image(imagename,200,200,true)
      Now when i add a messagebox at the end of the loop it seems to goes well.
      This is probably gonna be something stupid, i really have an off day on coding SU ruby.
        Are you doing that within a start_operation block that disables the UI?
          Jim
          Not 100% sure, but...
          What is the Scene transition time set to? Either set it to 0, or wait for the Scene animation to finish before writing the image.
          • P
            Pout
            ThomThom:
            no, but i'll give it a shot
            Jim:
            scene transitions are off
              @pout said:
              ThomThom:
              No - I was thinking that might be why it didn't work.
              Maybe you can use view.refresh ?
                Jim
                Ah, there are no scenes, so no scene tranistions.
                Oh, and even simpler: πŸ˜‰
                standardviews = %w(viewTop; viewBottom; viewFront; viewBack; viewRight; viewLeft viewIso;)
                standardviews.each do |view|
                  Sketchup.send_action(view)
                  # write image
                • P
                  Pout
                  Thx Jim for the code update
                  ThomThom,
                  I've tried just to see if there was any diff. and there is none.
                  I also already tried to do active_view.refresh after each view switch but that doesn't help either.
                  In the API this is the explanation on send_action:
                  The send_action method sends a message to the message queue to perform some action asynchronously.
                  I don't know if this could have something to do with it
                  Btw did you try the code?
                  Extra info, if you switch pages 'scenes) in the same loop all goes well.
                    Hm...
                    Tried setting the camera object itself instead of issuing the SU commands?
                    • P
                      Pout
                      I was thinking about that.
                      But I need the standard views attributes for that so i can use them in a camera definition.
                      I have not yet found a way to adress these standard views. (or i'm looking over it completely)
                        Attributes? Camera definitions?
                          You mean how to set the camera vectors?
                          I'd think just setting the camera to match X_AXIS, YAXIS and Z_AXIS should be enough... ?
                          • P
                            Pout
                            yes to 'copy' the standard cameras it would be great to be able to copy the eye, target and up of the standard cameras into new cameras so i can use those.
                            fact is i can't itterate over those standard cameras as shown above and i need the specific values of eye and target otherwise i need to calculate the center of the bounding box of all elements of the model to specify the eye and target.
                            At the other hand, maybe i'm lacking any sense today (you wouldn't be the first to say that today πŸ˜„)
                              And once you set the camera eye to target vector to suit an AXIS vector you need to use Sketchup.send_action("viewZoomExtents:") to see everything ???
                                The native standard view buttons doesn't zoom extent - but if that is what you want - then eye and target does not matter.
                                direction = Z_AXIS.reverse Sketchup.active_model.active_view.camera.set( ORIGIN, direction, direction.axes.y) Sketchup.active_model.active_view.zoom_extents
                                • P
                                  Pout
                                  Overview of the code for each standard view (informative)
                                  Top
                                  Bottom
                                  direction = Z_AXIS
                                  Front
                                  direction = Y_AXIS
                                  Back
                                  direction = Y_AXIS.reverse
                                  Left
                                  direction=X_AXIS
                                  Right
                                  direction=X_AXIS.reverse
                                  Iso
                                  direction=Geom;;Vector3d.new -0.666667, 0.666667, -0.333333
                                  This emulates the standard cameras, combined with zoom extents.
                                  Credits to ThomThom!
