    3D Scanning on the cheap
    53 Posts 13 Posters 52.0k Views 13 Watching
    • jo-keJ
      jo-ke
      hmm. I'll think of buying it.....
      But I want to see more results
      http://www.zz7.de
      • jo-keJ
        jo-ke
        Scanner arrived today! Can't wait to try it.
        πŸ˜„
        http://www.zz7.de
        • marvins_dadM
          marvins_dad
          Neat - interested in hearing your experiences/seeing what the ouput (or input) looks like.
          My Gallery
          • jo-keJ
            jo-ke
            OK. First object scanned, not to bad for the beginning. I opened it on sculptris and reduced the mesh. (Thank you)
            But I still have a problem of importing the .obj to SU. It still doesn't work
            http://www.zz7.de
            • jo-keJ
              jo-ke
              I was sucessful by importing the obj to blender, so I exported it to 3ds and then I was able to import to SU 😎
              Here's the result:
              Not bad for the very first scan....
              kopf.skp
              http://www.zz7.de
              • GaieusG
                Nice first scan indeed. Trying my hands out on it with Twilight ATM
                πŸ˜‰
                5 passes with easy 09 at 1024x786 (resized to 800x600some just under 12 minutes).
                Interesting hair style however. I do not know what causes it.
                • GaieusG
                  Well, it seems to be the procedural marble material. Here is another version where it's more visible:
                  • T
                    tfdesign
                    That's very odd! You look like a giant boiled sweet! 😲
                    • jo-keJ
                      jo-ke
                      First weekend of testing this funny tool.
                      My idea was to build a 3D model of my wife. As I'm not good enough to model the shape by hand, the scanner in a good idea to build the ground shape.
                      Let's start with the object and the first scans:
                      http://www.zz7.de
                      • jo-keJ
                        jo-ke
                        In the next step the different scans can be grouped and the build the new shape
                        after that I opened the file in sculptris
                        http://www.zz7.de
                        • jo-keJ
                          jo-ke
                          here I have the possibility to smooth the surface and to reduce the mesh
                          http://www.zz7.de
                          • jo-keJ
                            jo-ke
                            as I still have problems to import .obj- files to su I opended the file in meshlab and saved it in the 3ds- format.
                            Then it was easy to import to SU
                            There I smoothed it again
                            http://www.zz7.de
                            • jo-keJ
                              jo-ke
                              so, time to render with twilightrender and have some fun...
                              http://www.zz7.de
                              • jo-keJ
                                jo-ke
                                I prepared a face- texture and applied it as a projection to the mesh.
                                I found some nice bodys at the warehouse and I took these things together
                                http://www.zz7.de
                                • jo-keJ
                                  jo-ke
                                  and another one...
                                  http://www.zz7.de
                                  • T
                                    tfdesign
                                    Great stuff jo-ke! πŸ˜„
                                    I need to have a go at this too.
                                    • jo-keJ
                                      jo-ke
                                      the second avatar is finished.
                                      A shot with me and my wife at our court
                                      http://www.zz7.de
                                      • jo-keJ
                                        jo-ke
                                        Modelling the hair was tricky, then I used the fur plugin
                                        http://www.zz7.de
                                        • jo-keJ
                                          jo-ke
                                          OK here's the another result
                                          http://www.zz7.de
                                          • MarianM
                                            Marian
                                            Are you really that tall? You look a bit too scaled up.
                                            • 1 / 3
