    Render This - Chair Loft
    112 Posts 55 Posters 22.0k Views 55 Watching
    • dermotcollD Offline
      dermotcoll
      Jo-ke,
      What is it with you and the female form!!!?? πŸ˜‰
      When you burn your arse - you gotta sit on the blisters!!
      • boofredlayB Offline
        boofredlay
        @viztecture said:
        Here's my lil low res stab at it, ....Squatters dinner party
        Adam, that is very cool. I love the floor the most.
        Jo-ke, I will try a size 9 1/2 please πŸ˜„
        stereofidelic, very cool as well.
        • V Offline
          Viztecture
          cheers eric, i must say thats alot of blood...u ok? πŸ˜‰
          http://www.viztecture.mfbiz.com
            boofredlay
            Ha ha. Here is another "run" at that setup. I changed the viewing angle and added a bit then let it run overnight.
              Here's a quick 'Octane Render' version with very little tweaking...Chair01.png
              • marvins_dadM Offline
                marvins_dad
                So the squabble was over an engagement? πŸ˜†
                My Gallery
                  My first ever shot with Simlab Composer
                    boofredlay
                    Nice Gai. It is a bit dark and your brick bump is backwards.
                      d12dozr
                      Boring composition πŸ˜’ ...I'm working on my materials.
                      I made a bump map from the bricks, its attached if anyone wants to use it. For the newbies, I opened the brick texture in Photoshop from Sketchup's materials dialog box, made it grey-scale and increased the contrast.
                      Twilight + Neat Image
                      Brick Bump
                      http://goo.gl/f7ooYh
                      • daleD Offline
                        dale
                        Had to pitch in. The rose is a little lame.
                          blajnov
                          SimLabComposer
                          • Chris FullmerC Offline
                            Dale, I really like yours. THe materials are great! I love the floor, the floorboards, and the window frame, and the color hue and saturation - I think it is all perfect. Very nice!
                            @Gai & Eric, I've seen bricks get like that where they are not baked right and they wear down rather quickly, leaving the mortar exposed and the brick worn out between. Though generally speaking, I would agree its backwards πŸ˜„
                              boxman
                              some lovely work here.
                              jo-ke....have you got a 'thing' for shoes??!! lol
                              pugz thats very nice.....but i didnt make any of this model!!
                              • michaliszissiouM Offline
                                michaliszissiou
                                All these are fine renders, excellent job all of you.
                                @blajnov: I prefer two chairs here, not three, a sofa is even better. πŸ˜†
                                Well done.
                                  blajnov
                                  Well done.
                                  Pending a sofa ...
                                  ArtlantisStudio 3.0.3.2
                                  Time: 39 min. 40 sec.
                                  • olisheaO Offline
                                    olishea
                                    boxman: i think pugz was talking to me, i guess you are called Oli too right?! I think i saw your stuff on 3dwh....
                                    i need to have a go at rendering this
                                    oli
                                      @steve2802 said:
                                      ...How do you get the soft edge effect on the shadows?
                                      Maybe there are some tutorials on this sort of thing so if you could point me in the right direction...
                                      A lot of those suggestions would depend on the rendering software you used but forgot to mention.
                                      πŸ˜‰
                                      Generally speaking, a bigger size light will provide softer shadows in many rendering apps.
                                        steve2802
                                        @gaieus said:
                                        ...I actually just found it through trial and error - there's a soft shadow tick box in the sun settings - can't believe I didn't see it before...
                                        πŸ‘
                                        OK, if you check that box, you are going to get soft shadows. Now how soft they should be is up to the sun radius that you can also control.
                                        Note that soft shadows will increase render time a bit (the softer the longer). This scene would also be a cool one for volumetric lights in Kerky if you want to play around with it. That increases rendering time too however but the scene itself is not too complex so there should not be any problems.
                                          bocomofo
                                          Kerkyhtea render.
                                          HDRI sky, setting 20 MLT (BPT). left overnight...not much else...
                                          apart from a squinty camera!
                                          Not up to the standards of some of the work posted here...but i'm pleased with it!
                                          j
                                            steve2802
                                            Guys,
                                            I'm just getting into rendering so any feedback appreciated.
                                            Maybe there are some tutorials on this sort of thing so if you could point me in the right direction I would be grateful.
                                            Cheers,
                                            Steve.
                                            tried various things and it's getting better - guess i just need more practice.
                                            • 6 / 6
