    Render This - Chair Loft
    112 Posts 55 Posters 32.5k Views 55 Watching
    • jo-keJ
      jo-ke
      shoes, shoes, shoes
      http://www.zz7.de
        stereofidelic
        Hi all, here's my try.
        Thea + Photoshop
        • dermotcollD
          dermotcoll
          Jo-ke,
          What is it with you and the female form!!!?? ๐Ÿ˜‰
          When you burn your arse - you gotta sit on the blisters!!
          • boofredlayB
            boofredlay
            @viztecture said:
            Here's my lil low res stab at it, ....Squatters dinner party
            Adam, that is very cool. I love the floor the most.
            Jo-ke, I will try a size 9 1/2 please ๐Ÿ˜„
            stereofidelic, very cool as well.
            • V
              Viztecture
              cheers eric, i must say thats alot of blood...u ok? ๐Ÿ˜‰
              http://www.viztecture.mfbiz.com
              • boofredlayB
                boofredlay
                Ha ha. Here is another "run" at that setup. I changed the viewing angle and added a bit then let it run overnight.
                  Here's a quick 'Octane Render' version with very little tweaking...Chair01.png
                  • marvins_dadM
                    marvins_dad
                    So the squabble was over an engagement? ๐Ÿ˜†
                    My Gallery
                    • GaieusG
                      My first ever shot with Simlab Composer
                      • boofredlayB
                        boofredlay
                        Nice Gai. It is a bit dark and your brick bump is backwards.
                          d12dozr
                          Boring composition ๐Ÿ˜’ ...I'm working on my materials.
                          I made a bump map from the bricks, its attached if anyone wants to use it. For the newbies, I opened the brick texture in Photoshop from Sketchup's materials dialog box, made it grey-scale and increased the contrast.
                          Twilight + Neat Image
                          Brick Bump
                          http://goo.gl/f7ooYh
                          • daleD
                            dale
                            Had to pitch in. The rose is a little lame.
                            • B
                              blajnov
                              SimLabComposer
                              • Chris FullmerC
                                Dale, I really like yours. THe materials are great! I love the floor, the floorboards, and the window frame, and the color hue and saturation - I think it is all perfect. Very nice!
                                @Gai & Eric, I've seen bricks get like that where they are not baked right and they wear down rather quickly, leaving the mortar exposed and the brick worn out between. Though generally speaking, I would agree its backwards ๐Ÿ˜„
                                • B
                                  boxman
                                  some lovely work here.
                                  jo-ke....have you got a 'thing' for shoes??!! lol
                                  pugz thats very nice.....but i didnt make any of this model!!
                                  • michaliszissiouM
                                    michaliszissiou
                                    All these are fine renders, excellent job all of you.
                                    @blajnov: I prefer two chairs here, not three, a sofa is even better. ๐Ÿ˜†
                                    Well done.
                                    • B
                                      blajnov
                                      Well done.
                                      Pending a sofa ...
                                      ArtlantisStudio 3.0.3.2
                                      Time: 39 min. 40 sec.
                                      • olisheaO
                                        olishea
                                        boxman: i think pugz was talking to me, i guess you are called Oli too right?! I think i saw your stuff on 3dwh....
                                        i need to have a go at rendering this
                                        oli
                                        • GaieusG
                                          @steve2802 said:
                                          ...How do you get the soft edge effect on the shadows?
                                          Maybe there are some tutorials on this sort of thing so if you could point me in the right direction...
                                          A lot of those suggestions would depend on the rendering software you used but forgot to mention.
                                          ๐Ÿ˜‰
                                          Generally speaking, a bigger size light will provide softer shadows in many rendering apps.
                                            steve2802
                                            @gaieus said:
                                            ...I actually just found it through trial and error - there's a soft shadow tick box in the sun settings - can't believe I didn't see it before...
                                            ๐Ÿ‘
                                            OK, if you check that box, you are going to get soft shadows. Now how soft they should be is up to the sun radius that you can also control.
                                            Note that soft shadows will increase render time a bit (the softer the longer). This scene would also be a cool one for volumetric lights in Kerky if you want to play around with it. That increases rendering time too however but the scene itself is not too complex so there should not be any problems.
                                            • 1 / 6
