    This tripped me up (again) today
    25 Posts 6 Posters 5.8k Views 6 Watching
    • Dan RathbunD
      Dan Rathbun
      @tig said:
      because the variables a and b will then both refer to the same array?
      The references (not variables!) do not refer to the same array after the b = a.dup call. (Check their object ids.)
      They DO however point at the SAME objects in YOUR example because Integers are Immediate objects (there is ONLY 1 of each ordinal in the set of Ruby Integers.)
      After you ref a to point at the object that b points at, then both refs point at the same Array object.
      In Jim's example, he uses Strings, which are NOT Immediate objects. You can have more than 1 String "one", but in his case, the .dup method copies the Array object, but does not duplicate the individual element objects.
      It seems "nutty" but this is one of the lessons rubyists should be taught early. In Ruby, everything is an object, every object has a reference. Literal arguments, are converted to objects and assigned an anonymous reference by RUBY. Since the element objects in the array have a 'parent' object that IS referenced, they will not be swept up by Ruby's GC, even though they don't have a explicit reference.
      So.. an array is not a set of values (like it may be in BASIC,) in Ruby an array is a set of references, either explicit (managed by YOU,) or anonymous (managed by Ruby.)
      When you dup or clone the array, you copy the references.
      If you wish a completely different array:
      b = [] # a new Array object a.each {|e| b << e.dup}
      TIP In Ruby = is NOT "equals" (which is why there is an .equal? method.)
      It is the assignment operator, so your better off thinking and saying 'SPA' (Shall Point At.) Read:
      a = b
      as "The reference a shall point at the object that b references."
      @tig said:
      Perhaps your a = %w( one two three)
      is not quite the same as a = ["one", "two", "three"]?
      It IS the same, it's just a Ruby "TimToady."
      I'm not here much anymore.
      • Dan RathbunD
        Dan Rathbun
        For further reading, see this topic on References:
        By value or by reference?
        • Dan RathbunD
          Dan Rathbun
          This is interesting, in Ruby 1.9.x Core Docs, there is a method called:
          Array.dclone
          The source shows that it creates a totally new array, including new cloned elements, and handles nested arrays. (It's a recursive method.)
          # File lib/rexml/xpath_parser.rb, line 22
            def dclone
              klone = self.clone
              klone.clear
              self.each{|v| klone << v.dclone}
              klone
          Looks like it's an Array class extension defined in the REXML extended Library.
            Are .dup and .clone aliases?
              I think so. πŸ˜’
                Jim
                No, but I don't know the details.
                • AdamBA
                  AdamB
                  FWIW This whole area of Comp Sci is pretty tricky to resolve in programming languages generally because ultimately these references are not 'semantic free'.
                  Sometimes you want a 'deep' copy and sometimes you want a 'shallow' copy. The classic example is if you have a class Car which has an attribute which is a reference to the car manufacturer, when I copy the car, I generally wouldn't want to deep copy the entire Ford motor company (or whatever).
                  So languages essentially cannot a priori "know" what the meaning and therefore the intent of these references are, hence we have to either manually descend a parts hierarchy choosing to copy or not copy, or keep a top-level reference.
                  Adam
                    Jim
                    It might be eaier to explain by looking at object id's:
                    >> a = %w( one two three )
                    => ["one", "two", "three"]
                    >> b = a
                    >> a.object_id
                    => 23021928
                    >> b.object_id
                    => 23021928
                    Here is an image what what this means in the computer. Both a and b now reference the same object, an Array. However, note that each array element is a reference to another object.
                    When we .dup a, we get a new Array object, including it's elements. But remember the elements are just references to the original objects.
                    >> b = a.dup
                    >> a.object_id
                    => 23021928
                    >> b.object_id
                    => 22854408
                    Which can be seen by:
                    a[0].object_id == b[0].object_id => true
                    So when you .dup an array, you get a new array. Because the elements of the original array are references to a non-primitive type (String in this case,) the new array's elements reference the original elements.
                    As Dan says, there are no variables in Ruby, only references to object.
                    Here's someone else's explaination
                    When you copy an object, all you do is copy its set of instance variables, which are just references to other objects. For an array, the instance variables are its set of indexes, which again are just references. Copying an array just means making a new list of references, but the objects they point to remain unmodified and uncopied.
                    • Dan RathbunD
                      Dan Rathbun
                      NO, even though both create "shallow" copies:
                      • .clone copies the frozen and tainted state of the receiver object.
                      • .dup copies the tainted state of the receiver object.
                      In addition:
                      (http://phrogz.net/ProgrammingRuby/ref_c_object.html#Object.dup)":1q9fng7v]In general, clone and dup may have different semantics in descendent classes. While clone is used to duplicate an object, including its internal state, dup typically uses the class of the descendent object to create the new instance.
                      In general it is always safer to try using dup first (especially if you don't want to get a frozen object.)
                      (http://forums.sketchucation.com/viewtopic.php?f)":1q9fng7v]
                      @kwalkerman said:
                      So apparently, you can do face.clone, ... I if so, I might be able to determine what is happening with face.clone
                      Karen,
                      The .clone and .dup methods come from standard Ruby class Object, and create "shallow" copies. Ie, (from the book,) "the instance variables of the obj are copied, but not the objects they reference."
                      FYI: I went on to say not to use these methods with Sketchup's C++ objects (... until they get overriden methods that work correctly.)
                        I use clone a lot for SketchUp's objects...
                        What is the issue with SU's .clone?
                        • Dan RathbunD
                          Dan Rathbun
                          It WILL work for any classes that are subclasses of standard Ruby classes, such as Length, which is a subclass of Float.
                          It WILL work for any custom Sketchup classes that provide an overidden version of clone, such as:
                          Geom::Point3d
                          Geom::Transformation
                          Geom::Vector3d
                          • note that these work like dup and not clone (in that they do not copy the frozen state of the receiver.)
                          The Ruby inherited edition will not work for many C++ objects like Sketchup::Face.
                          To get around this, TIG shows in the other thread, how to use Sketchup::Group.copy to "clone" Sketchup::Drawingelement subclass objects, like Faces, Edges, etc.
                          Geom::BoundingBox objects can be copied by using their .add method (if clone or dup does not work):
                          bb2 = Geom::BoundingBox.new.add( bb1 )
                            So SU doesn't override .dup for Point3d and Vector3d?
                            That would explain why I had problems before when I tried .dup for Point3d. I've had to use .clone.
                            • Dan RathbunD
                              Dan Rathbun
                              Yepper... I remember having that discussion with you in another topic thread.
                              Either most the Sketchup classes need to override Ruby's .dup and .clone with methods that work, or they should be removed for those classes.
                              And... a point about .freeze, we would not want to freeze most of the Ruby objects that Sketchup needs to modify (data classes and any object class that is kept in the model.) So copying the frozen state doesn't mean much, so the overriden dup could likely be just an alias for the overriden clone.
                              In most Sketchup classes the .freeze method should be also removed. It can be done for many of them, by removing it from Sketchup::Entity.
                                I passing... IF you want to make a completely separate array based on another array's 'reference' then us
                                so
                                a=[1,2] b=[]+a
                                makes array a and array b separate arrays as
                                a[0]=99
                                gives
                                a ==> [99,2]
                                but b is not affected
                                b ==> [1,2]
                                  August
                                  I am SO glad that I found this 5-year-old thread. I, too, was having trouble copying an array and having the copy be independent of the original.
                                  In my case, I had an array of points that I had generated, and I wanted to create a closed curve from them. My strategy was to copy the point array
                                  curve = []
                                  curve = point
                                  and then add point[0] to the end,
                                  curve << point[0]
                                  so that a curve created from the new curve[] array would return to its beginning point.
                                  path = ents.add_curve curve
                                  But the above sequence kept adding the extra point to the point array too.
                                  What I finally kludged around to was
                                  curve = []
                                  curve = point[0..(point.length - 1)]
                                  curve << point[0]
                                  Using the sample code from the above discussion, I have tested and confirmed that
                                  b = a.dup
                                  and
                                  b = a.clone
                                  both have the same problem as my initial
                                  curve = point
                                  And I have confirmed that
                                  b = a.dclone
                                  gives an error.
                                  I'm using SU 15, which is supposed to have Ruby 2.0 and Dan notes that dclone is in 1.9, so I'm confused.
                                  I do have a kludge that works. Maybe it's not so much of a kludge after all. I understand the issue a little more, and hopefully I will remember it in the future.
                                  FWIW, I hope this helps,
                                  August
                                  β€œAn idea, like a ghost, must be spoken to a little before it will explain itself.”
                                  [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
                                    The assignment
                                    curve = point
                                    means the array 'curve' refers to the array 'point' - they are essentially referencing the same thing, whereas...
                                    curve = point.clone
                                    means the array 'curve' is a separate array, which has been made as a copy from the array 'point',
                                    Consider this...
                                    curve = point + [ point[0] ]
                                    which achieves you aim for a 'curve' array defining a 'loop', but done in the one step.
                                    It combines the array 'point' and a new array made from the first element of that array, all in a new array named 'curve'.
                                    Incidentally consider naming arrays and other collections in the plural - it is is easy to follow the code - so the array named 'points' consists of a collection of elements, each of which is a 'point'.
                                    The 'curve' array would also perhaps be better named 'curve_points'
                                      August
                                      Thanks TIG.
                                      I had not tried using that additional set of square brackets. It makes sense.
                                      As for naming, I thought about using plural in the first place, but most of my usages were as singular references, point[0], point[1], ... point[n-1], point[n] where the singular read better to me. I like "curve_points" -- that is always used as a group, never individually, so plural reads much better there.
                                      Thanks,
                                      August
                                        August
                                        TIG, I'm not sure that clone does what you say it does.
                                        This page, http://lukaszwrobel.pl/blog/copy-object-in-ruby suggests that a clone's elements still point to the original elements so some changes to one will indeed show up in the other. That's what I found with my initial testing.
                                        Above, Dan says
                                        Geom::Point3d
                                        Geom::Vector3d
                                        So I didn't use .clone.
                                        And yet, I just tried in the SU Ruby console:
                                        > a = ["a","b", "c"]
                                        ["a", "b", "c"]
                                        > b = a
                                        ["a", "b", "c"]
                                        > c = a.clone
                                        ["a", "b", "c"]
                                        > d = a << "d"
                                        ["a", "b", "c", "d"]
                                        > a
                                        > b
                                        > c
                                        ["a", "b", "c"]
                                        > a[2] = "3"
                                        3
                                        > a
                                        ["a", "b", "3", "d"]
                                        > b
                                        > c
                                        ["a", "b", "c"]
                                        > d
                                        which shows that for these two kinds of changes, the clone is not affected.
                                        I'm still not clear on when I can use .clone and when not, nor do I really understand shallow vs. deep copies and frozen objects, so for now, unless I'm doing tens of thousands of copies, I may use a brute force method becuase the shortcuts seem so problematical.
                                        Thanks,
                                        =A=
                                        • Dan RathbunD
                                          Dan Rathbun
                                          What I actually said was that the REXML library (beginning in Ruby 1.9,) modified the Array class, by adding the dclone method.
                                          In order to use it, you must either precede it's use with:
                                          require "rexml/document"
                                          or use a refinement.
                                          (1) Using the REXML library:
                                          ` require "rexml/document"
                                          true
                                          a = []
                                          a.respond_to?(:dclone)
                                          true`
                                          (2) Refinement module:
                                          <span class="syntaxdefault"><br />module&nbsp;August<br />&nbsp;&nbsp;module&nbsp;DeepCopy<br /><br />&nbsp;&nbsp;&nbsp;&nbsp;refine&nbsp;</span><span class="syntaxkeyword">Array&nbsp;do<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">def&nbsp;dclone<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;klone&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">self</span><span class="syntaxkeyword">.clone<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">klone</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">clear<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">v</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">klone&nbsp;</span><span class="syntaxkeyword"><<&nbsp;</span><span class="syntaxdefault">v</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">dclone</span><span class="syntaxkeyword">}<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">klone<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;end<br />&nbsp;&nbsp;&nbsp;&nbsp;end&nbsp;</span><span class="syntaxcomment">#&nbsp;class&nbsp;Array<br /><br />&nbsp;&nbsp;</span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#&nbsp;refinement&nbsp;module&nbsp;DeepCopy<br /></span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#&nbsp;Author's&nbsp;namespace<br /><br /><br /></span><span class="syntaxdefault">using&nbsp;August</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">DeepCopy<br /><br />module&nbsp;August<br />&nbsp;&nbsp;module&nbsp;SomePlugin<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;a&nbsp;</span><span class="syntaxkeyword">=&nbsp;[</span><span class="syntaxstring">"august"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"dan"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"tig"</span><span class="syntaxkeyword">]<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">b&nbsp;</span><span class="syntaxkeyword">=&nbsp;</span><span class="syntaxdefault">a</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">dclone<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;puts&nbsp;</span><span class="syntaxstring">"a&nbsp;is;&nbsp;#{a.inspect}"<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">"b&nbsp;is;&nbsp;#{b.inspect}"<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">"changing&nbsp;a[1]&nbsp;to&nbsp;\"bob\""<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">a</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">]=&nbsp;</span><span class="syntaxstring">"bob"<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">"a&nbsp;is;&nbsp;#{a.inspect}"<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">puts&nbsp;</span><span class="syntaxstring">"b&nbsp;is;&nbsp;#{b.inspect}"<br /><br />&nbsp;&nbsp;</span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#&nbsp;module&nbsp;SomePlugin<br /></span><span class="syntaxdefault">end&nbsp;</span><span class="syntaxcomment">#&nbsp;Author's&nbsp;namespace<br />&nbsp;</span><span class="syntaxdefault"></span>
                                          Any call to using() must occur within the TOPLEVEL_BINDING.
                                          This restriction has been removed in later versions of Ruby 2.2+, and the experimental warning that is output on calls to refine has also been removed. (Ie, refinements are no longer experimental and calls to using can happen inside specific module and class scopes.)
                                          If you want to see that all the elements of the arrays are different objects, you can iterate them and compare their object id numbers.
                                            August
                                            Thanks Dan,
                                            So refine allows me to add my own operators to an existing class? That's a sweet (and dangerous) concept.
                                            I'll have to put that on the back burner for now. I'm still working on basic Ruby.
