    Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
    368 Posts 150 Posters 2.1m Views 150 Watching
      andersonassociatesla
      @andersonassociatesla said:
      How do I download ruby scripts to my computer?
      Here is the link http://forums.sketchucation.com/viewtopic.php?f=323&t=6708&hilit=plugin#p42783.
      The Zip file is at the bottom of the first post.
      Thanks Fredo!
        craigt
        How do you download push pull. Benn trying for a while and cant find the link
        • COSEDIMARCOC Offline
          COSEDIMARCO
          First post in the first page of the Tread ๐Ÿ˜„
          [floatl:2wjeiugn]COSEDIMARCO - The Website[/floatl:2wjeiugn]
            claudia_mochy
            I installed lastest versions of LibFredo and JointPushPull, but
            when I open SU appears an error message: Error Loading File jointpushpull.rb
            No such file to load -- LibTraductor.rb.
            What's wrong?
            • Chris FullmerC Offline
              His first post mentions that you will need that file and a few others installed to run this plugin. You can search the plugins forum for it. It has its own thread dedicated to it I think.
                chouaibcl65
                thank you
                  theark
                  Thanks a lot.You are great. ๐Ÿ˜ฎ
                    TESLER
                    firstly, I have to say that this us one of the best plugins available for skecthup . I been using this plugin a lot lately, on some pretty detailed 3d surfaces, and I have been coming across a bug. when I use this plugin, it will start normally, then abort leaving only some of the faces it will say something like 4% complete in the measurements bar. I have tried re-downloading the plugin many times with no effect. I am running this on mac OS 10.6.3. Is there anything I can do to fix this problem?
                    thanks, TESLER
                    • fredo6F Offline
                      Tesler,
                      The best would be to post a model where you have this problem so that I can check what's could be wrong. JPP won't handle all situations for sure, and it may contain bugs, for sure as well.
                        TESLER
                        hi,
                        thanks for the response. i have tried to upload a model to the internet, but it is now not starting generating the geometry. instead, I have a picture of the problem. this is a screenshot of what was happening. i selected the area to extrude, (the whole model) and then used the JPP tool to extrude about an inch inward. then, it only showed some of the faces in purple outline. when it was done generating the geometry, only the faces that had the purple lines would be extruded. hope this helps you find the problem http://sketchup.google.com/3dwarehouse/details?mid=1a5515310e3adac6b030d9c7c2d7c9e9
                        thanks, tesler
                        • fredo6F Offline
                          @tesler said:
                          hi,
                          thanks, tesler
                          It is difficult to see what's right or wrong on the picture.
                          Can you attach the skp file to this thread.
                          Also, you can do the JPP progressively by portions. did you try it?
                            TESLER
                            hi,
                            I got the plugin to work again, but it is still not working right. I did try doing the model in chunks, and it seems to have worked. it will just take linger, but that is alright. just for reference, there is an example of the problem attached.
                            thanks, TESLER
                            tailfin panel lines.skp
                            • fredo6F Offline
                              @tesler said:
                              hi,
                              thanks, TESLER
                              The problem was in the texturing part of the script. For whatever reasons, it was blocking the computation.
                              I modified the JPP script to overcome the issue (skip texturing in case of problem) and tried on your model. Below is the result, noting that it took 15 minutes to process all 2,300 faces and 7,000 edges (you get a blank screen, but the script is still computing). Also, I noticed that you have a few faces which are missing in your original model.
                              I am updating the jointpushpull script in the main post.
                              tailfin JPP.zip
                              • N Offline
                                NOLASaintTM
                                Suggestion Add a function where you can create a new face when you joint push/pull.....like the CTRL push/pull... What do you guys think?
                                "There are only 2 seasons in [color=#008000:29bx2alm]Louisiana[/color:29bx2alm]: [color=#BF0000:29bx2alm]Hurricane Season[/color:29bx2alm] and [color=#BF0000:29bx2alm]Summer[/color:29bx2alm]" My Models: [url:29bx2alm]http://sketchup.google.com/3dwarehouse/search?viewer=06262141413891559654&scoring=m[/url:29bx2alm] [color=#0000FF:29bx2alm]G[/color:29bx2alm][color=#FF0000:29bx2alm]O[/color:29bx2alm][color=#FFBF00:29bx2alm]O[/color:29bx2alm][color=#0000FF:29bx2alm]G[/color:29bx2alm][color=#00BF00:29bx2alm]L[/color:29bx2alm][color=#FF0000:29bx2alm]E[/color:29bx2alm]!!!
                                • boofredlayB Offline
                                  boofredlay
                                  Using the thickening option does the same thing. When you activate JPP press the tab key for options.
                                  • N Offline
                                    NOLASaintTM
                                    ๐Ÿ˜• Thanks. Lol.
                                      saedobaid
                                      thx a lot...u help me ๐Ÿ˜„)
                                        pmolsen
                                        Whenever I use the plugin and specify Erase Original Faces plus No Borders, it deletes the original faces but leaves all the surrounding lines from the faces. I am on the latest version (12 June 2010).
                                        Is that a bug or is there some reason why people would want numerous orphaned lines left behind?
                                        • fredo6F Offline
                                          It's probably a bug. Will have a look
                                            Sir
                                            yup thats happening for me too, skp7 pro, win 7 64bit
                                            • 18
                                            • 19
                                            • 8 / 19
