    SketchUp RUBY API Wishlist [way of coding wishes, please]
    107 Posts 46 Posters 48.9k Views 46 Watching
      I've also made a material.name="new_name" method here http://forums.sketchucation.com/viewtopic.php?p=167219#p167219 ...
        material.name="new_name" method now v1.1 - here http://forums.sketchucation.com/viewtopic.php?p=167219#p167219
        Temp folder fixed for Mac users...
        • N Offline
          narongwit12
          Be able to track the shadow area on each face. This could make the calculation of shading possible for energy simulation.
            BTM
            • to have the 5th (optional) argument for write_image as 'Transparent Background' if the file type is .png
              Dan Rathbun
              Sketchup::load
              The Sketchup::load method does NOT expose the wrap argument, so we can specify wrap=true for rbs scripts.
              For some unknown reason, the Google team defeated, or just didn't pass the 2nd argument (wrap) on to the aliased standard load, when they overrode it to handle rbs decrypting.
              Please fix this!
              _
              I'm not here much anymore.
                Pout
                Here is my list:
                • Tig, although your solutions on material.name=, layer.delete, material.delete are good, it seems to me it would be much easier to just have them in the API. So i second the proposals of ThomThom
                • Also i second the proposal of Morisdov concerning the add_framechange_observer not firing when creating movies or when working in layout. It should fire there to.
                • make the entity.id consistent throughout different SU sessions (it changes now from time to time)
                • it would be great if you could just select an entity based on a parameter (eg. entity.id) without looping all the entities in the model
                • being able to access the font/size and other parameters of a text
                • make a difference between the execution of scripts and the interface so it is possible to incorporate a 'stop script' button for example. Now the interface freezes as long as scripts are running. This makes users believe the execution of the script has halted and Sketchup has stopped working.
                • ...more to come
                  And it would be faster.
                  Ditto!
                  Ditto. If you have a script that requires observers attached to some objects one want these to be reattached when the model is loaded. Currently one has to iterate the whole model to find the entities, and one has to attach an attribute to be able to find the correct one - which means string comparisons which are really slow.
                  So a better way to directly reference entities across sessions would be a great addition.
                  while true puts 'Ditto!' end
                    Pout
                    does anyone know if any of the remarks here will be taken into consideration in a new version?
                      Dan Rathbun
                      @dan rathbun said:
                      Sketchup::load
                      Please fix this!_
                      Taking this a step further.
                      Since the rbs code blocks are eval'd, and Sketchup.load is an override (redefinition,) just pass the 2nd argument to Sketchup.load (if given,) on as the 2nd argument to the eval method.
                      That way developers can instantiate a binding() to their custom namespace(s), and have the code evaluated within that scope.
                      This can also give the GSUT the opportunity to protect some Google namespaces, within the argument validation block of the Sketchup.load method (ie: raise a custom "NotAllowedError" exception.)
                        Dan Rathbun
                        EDITED:Get||Set Layer Material & Color
                        Added missing "wish" statement to set Layer color in the example I gave (the last statement.)
                          Dan Rathbun
                          @thomthom said:
                          Being able to set Layer colour.
                          ..and also a "getter" method to read the color.
                          Actually when you manually click the color button in the Layers dialog, the Edit Material dialog appears. If you choose 'Use texture image' and assign a texture file, the layer will be displayed with that texture over the layer color, when 'Color by Layer' is true, and rendering mode is 'Shaded with Textues'.
                          Issues:
                          (1) Technically, Layers have a material attribute that holds a Sketchup::Material object.
                          (2) These material objects ARE saved with the model, but NOT accessible thru the API.
                          (3) When a layer is assigned a texture, it does not appear in the "In Model" Materials Collection, and it shouldas well as allow us to assign a name (thru the layer's material object.)
                          In the UI manual mode the new material could be given a temporary name equal to the Layer name, so the user could manually rename it thru the Materials Browser, or we could name it in a subsequent ruby statment like:
                          model.materials['Layer3'].name='PolishedWood'
                          We should also then be able to go totally automatic thru the API, thus:
                          mat = model.materials.add('PolishedWood') mat.texture = 'wood/polished.png' mat.color = [195,144,86] model.layers['Layer3'].name = 'Surface' model.layers['Surface'].material = 'PolishedWood' model.rendering_options['DisplayColorByLayer'] = true
                          Later on getting a layer's color, we could do:
                          surfaceColor = model.layers['Surface'].material.color
                          and setting it to some other color:
                          surfaceColor = [127,127,200] model.layers['Surface'].material.color = surfaceColor [*]
                          ****** So what we really need is the Sketchup::Layer object's material attribute getter and setter methods exposed in the API, along with the manual UI naming hack.
                          EDIT: [* (2010AUG05) Added missing "wish" statement to set layer color.]
                            kwalkerman
                            Seconded on the Layers usability, also, it would be great to be able to do:
                            Layers.active_layer
                            Layers[layer] = active
                            A consistent entityID would be awesome. The entity should maintain the ID if it is deleted, and then undeleted as well.
                            Pages:
                            In addition to retaining information on which layers are on and off, should also be able to retain the active layer for each page.
                            Karen
                              hm... never thought of that inconsistency before...
                              model.materials.current vs model.active_layer
                                Dan Rathbun
                                "current and "active" should aliases for each other.
                                  kwalkerman
                                  Cool. Thanks again.
                                    Dan Rathbun
                                    @kwalkerman said:
                                    Cool. Thanks again.
                                    No problem.
                                    (bumping the topic..)
                                    • Made edits to the Layers code example* Added a second code example for Layer class.See previous post...
                                      Jim
                                      I like this idea, particularly useful when adding text to Scenes. It seems quite possible using an Observer.
                                        Jim
                                        Well, don't leave out Pages.selected_page!
                                          Dan Rathbun
                                          I don't know about that one... Pages are special. Even though you "select" a Page, depending on transition time, Sketchup can be animating somewhere between the previous page and the selected one.
                                          A FrameChangeObserver is needed to know when the animation is complete. Only at that point would I 'technically' say that a Page was the "active_page" or "current_page."
                                          @Karen. You can get an array of the hidden layers for a Page:
                                          mypage.layers
                                          so the visible layers would be:
                                          my_vis_layers = model.layers.to_a - mypage.layers
                                          • why they didn't name the method Page.hidden_layers, I don't know.
                                            Dan Rathbun
                                            @jim said:
                                            @kwalkerman said:
                                            ..., should also be able to retain the active layer for each page.
                                            But when you add text to Scenes (Pages,) are you drawing to the model, or drawing to the View ??
                                            If it's the View, then the active layer does not matter.
                                            The active layer is a property of the model. A Scene (Page,) is a View mechanism, which does not "have" layers; it only 'remembers' which of the model's layers to hide or show. A layer also has "new page behaviour" which it can tell new Scenes (Pages,) how to 'remember' their visibilty.
                                            I can see some problems for other scripts, if the active layer was automatically changed when a Scene changed. There would need to be some kind of toggle to turn the "auto" feature on and off.
                                            In addition, their would need to be scoping. What if an Observer was to be triggered while this "auto layer" feature was on? Outside the current script (or scope,) the Observer may want to "see" or "use" another layer as the active one.
                                            It also occurs to me, that we are supposed to always be drawing primitives on "Layer 0", but still some modelers want to draw on other layers (construction lines especially.)
                                            Anyway.. we'd need to consider this carefully. It could be a disaster.
                                            • 4 / 6
