    [Plugin] $ Copy Brick (Updated 5/04/11)
    64 Posts 22 Posters 57.9k Views 22 Watching
      Daniel S
      @solo said:
      Try using the arrow keys
      It is exactly the same... the preview box show a good orientation... but when I insert the group the orientation is always the same, it dosen´t change.
      Daniel S
        Daniel S
        More information...
        if I have the ruby console open it says:
        WARNING; make_unique is a deprecated methodof Sketchup;Group
        Error; #<NoMethodError; undefined method `transformation_rotation_array' for #<Kirpichi_create_raspolozhenie;0x8970330>>
        (eval);787;in `kirpichi_create_raspolozen'
        (eval);622;in `onLButtonDown'
        (eval);787
        Daniel S
        • soloS Offline
          I get the same issue now, however if you initially use the arrow keys and not the protractor thing then it works, as soon as you touch the protractor it stops working...glitch.
            sahi
            @daniel s said:
            But I have a problem with the orientation/rotation... I tried with groups, components but without luck.
            I understand. The problem in the axes
            I'll try to fix this error.
              sahi
              I corrected this error.
              First Message Brick_2.zip
              • soloS Offline
                works great now.
                  sahi
                  Upgrade plugins First Message Brick_3.zip
                    Daniel S
                    Sahi, Thank you for the quick update.
                    It works very well.
                    But there is a small cosmetic bug... look at the wireframe using groups.
                    In this .gif I show that using components looks well and groups not:
                    This happens with simple boxes too.
                    Daniel S
                      sahi
                      Fixed
                      Upgrade plugins First Message Brick_4.zip
                        sahi
                        @xrok1 said:
                        thats cool! but where's the brick part of the plugin? 😄
                        Yes
                        I'm working on it
                        • kenK Offline
                          ken
                          This program shut my Sketchup down without a error. Stops every time I pick the icon.
                          However, thanks for the plugin, I know you will get it working.
                          Ken
                            sahi
                            Ken
                            Double Click = Exit
                            • boofredlayB Offline
                              boofredlay
                              Ooo, nice.
                              • X Offline
                                xrok1
                                @sahi said:
                                Yes
                                I'm working on it
                                  Daniel S
                                  Sahi, thanks again...
                                  I was trying your plugin... and discover a new issue.. but this one is very important
                                  I put 60º in the protractor but the result is 59,38º for example.
                                  If I put 30º the result is similar, but not 30°.
                                  Perhaps the problem is with my units... I attach a .skp file.
                                  Daniel S
                                  issue.skp
                                    sahi
                                    Fixed
                                    Upgrade plugins First Message Brick_6.zip
                                      tomislavm
                                      • urgenU Offline
                                        urgen
                                        Ooo very useful! 🎉 thanks! 👍
                                        --pupil forever...------
                                          sahi
                                          Upgrade plugins First Message Brick_7.zip
                                            sahi
                                            Upgrade plugins First Message Brick_8.zip
                                            • 1 / 4
