    [Plugin] $ Copy Brick (Updated 5/04/11)
    64 Posts 22 Posters 39.9k Views 22 Watching
      sahi
      Copy group ( $ 1.05.2011)
      [flash=800,600:17il3e8h]http://www.youtube.com/v/reQcr_3L-HI[/flash:17il3e8h]
      Enter >> Exit
      Double click >> Exit
      Remove the previous script from a folder Plugins "kirpich.rbs" and "blokk.png"
      downloaded http://stroyka.name/brick.php
      EDIT: Inserted Video by rclub24
      • soloS Offline
        Very cool plugin mate!!!
        I love the rotation tool it comes with.
          Daniel S
          Awesome Sahi!!!
          Love the UI!!
          But I have a problem with the orientation/rotation... I tried with groups, components but without luck.
          Look at this .gif.
          Any idea on how to fix it?
          Thank you,
          Daniel S
          • X Offline
            xrok1
            thats cool! but where's the brick part of the plugin? 😄
            • soloS Offline
              Try using the arrow keys
                Daniel S
                It is exactly the same... the preview box show a good orientation... but when I insert the group the orientation is always the same, it dosen´t change.
                Daniel S
                  Daniel S
                  More information...
                  if I have the ruby console open it says:
                  WARNING; make_unique is a deprecated methodof Sketchup;Group
                  Error; #<NoMethodError; undefined method `transformation_rotation_array' for #<Kirpichi_create_raspolozhenie;0x8970330>>
                  (eval);787;in `kirpichi_create_raspolozen'
                  (eval);622;in `onLButtonDown'
                  (eval);787
                  Daniel S
                  • soloS Offline
                    I get the same issue now, however if you initially use the arrow keys and not the protractor thing then it works, as soon as you touch the protractor it stops working...glitch.
                      sahi
                      I understand. The problem in the axes
                      I'll try to fix this error.
                        sahi
                        I corrected this error.
                        First Message Brick_2.zip
                        • soloS Offline
                          works great now.
                            sahi
                            Upgrade plugins First Message Brick_3.zip
                              Daniel S
                              Sahi, Thank you for the quick update.
                              It works very well.
                              But there is a small cosmetic bug... look at the wireframe using groups.
                              In this .gif I show that using components looks well and groups not:
                              This happens with simple boxes too.
                              Daniel S
                                sahi
                                Fixed
                                Upgrade plugins First Message Brick_4.zip
                                  sahi
                                  Yes
                                  I'm working on it
                                  • kenK Offline
                                    ken
                                    This program shut my Sketchup down without a error. Stops every time I pick the icon.
                                    However, thanks for the plugin, I know you will get it working.
                                    Ken
                                      sahi
                                      Ken
                                      Double Click = Exit
                                      • boofredlayB Offline
                                        boofredlay
                                        Ooo, nice.
                                        • X Offline
                                          xrok1
                                          @sahi said:
                                          Yes
                                          I'm working on it
                                            Daniel S
                                            Sahi, thanks again...
                                            I was trying your plugin... and discover a new issue.. but this one is very important
                                            I put 60º in the protractor but the result is 59,38º for example.
                                            If I put 30º the result is similar, but not 30°.
                                            Perhaps the problem is with my units... I attach a .skp file.
                                            Daniel S
                                            issue.skp
                                            • 1 / 4
