    Export For CAM software
    extensions
    51 Posts 14 Posters 20.0k Views 14 Watching
      dedmin
      I was hopping someone could make this with SketchUP - I think it is possible. But only limited attempts here and there. What I have found so far:
      http://www.sketchdata.com/
      http://sketchuppluginreviews.com/2010/04/30/phlatscript-google-sketchup-plugin-review/
      http://www.cnczone.com/forums/showthread.php?t=100225&highlight=SketchUP
      There is a lot of useful data we can put inside a dynamic component, but the problem is to export it from SketchUP in way suitable for production. At least as a cvs or html report and cutlis. I made components that calculate area, price, contains data for the grain, banding, oversize and etc., but I have to learn Ruby to make a script that exports this data.
      AS a compromise if we can export dynamic's component options to a cutting optimization software as CutListPLus it can export the cutting diagram as a dxf for CNC. I'm sure there is a huge demand for a such softwre and we a ready to pay for it! See this thread: http://www.woodweb.com/cgi-bin/forums/cad.pl?read=660643
      • honoluludesktopH Offline
        honoluludesktop
        Yvan, Why does the dxf file have to start with the largest face of each component? What is the selection criteria for the following faces, and how do want to handle sub components?
        If you re-post this in the plug-in section, it would help people like TIG if you provide as complete a description of your requirements as you can.
        • Y Offline
          yvan
          Maybe the plugin should let you manually select the faces to export? The face with most machining.
          Catalyst Interiors Pty. Ltd. - shopfitters Adelaide South Australia
            sketchdata
            We are currently working on a project to export data from SUP to the 2020 Shopware software Product Planner. We are also beginning work on a reporting program to generate PDF and text files, but having trouble finding a solution that will work on both PC and Mac. Future plans do include SUP plug-ins for defining and exporting CNC machining operations to a DXF file.
            • X Offline
              xrok1
              project or product? ๐Ÿ˜‰
              โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
                dedmin
                I checked some of yours plugins and dynamic components and they look promising. We badly need reporting plugin and CNC connection. It is a shame that all the power of dynamic components cannot be used for calculations, cut list and reporting!
                • Y Offline
                  yvan
                  Do you have a link to your plugins?
                    dedmin
                    See my post above - the first link.
                      dedmin
                      I'm not very familiar with the CAM technology, but could the way SketchUP handles the geometry be a problem? That everything is just a bunch of lines, instead of real curves?
                        dedmin
                        I know this, but the question remains.
                        • Y Offline
                          yvan
                          Sketchup is a mesh modelling software. you can find more info about mesh modelling here: http://en.wikipedia.org/wiki/Polygon_mesh.
                          Smooth curves can be achieved by increasing the number of segments.
                          With a CNC flatbed router we currently export faces as DXF polylines with [url=http://www.guitar-list.com/download-software/convert-sketchup-skp-files-dxf-or-stl:lzs2i8uh]skp_to_dxf plugin[/url:lzs2i8uh] and then import these dxf files in the CAM software for tooling and G code generation.
                          • Y Offline
                            yvan
                            I will not give-up!
                            SU's dynamic components architecture is so powerful that it would be a shame if it cannot be used for manufacturing.
                            My wish is to find a script that would let you select a face in each components as primary face to be sent to the CNC.
                            http://www.catalystinteriors.com.au/images/stories/sketchup/select_pmf.png
                            Then,
                            http://www.catalystinteriors.com.au/images/stories/sketchup/exported_face.png
                            http://www.catalystinteriors.com.au/images/stories/sketchup/layers.png
                            Then all parts should be exported as individual dxf polylines in a specified folder ready for import in a CAM/nesting package.
                              dedmin
                              Fully agree with You!! I wonder why nobody did this already - there are so many fellow woodworkers ready to pay for this!! But when You export a 5mm circle from SketchUP as .dxf it is not a circle anymore - that is why I asked above if this is a problem with CAM?
                                dedmin
                                And there is need for a hole drilling plugin like this one - http://www.smartmachining.com/
                                  sketchdata
                                  I think holes will work better if a component is used, that way center point is easy to determine, and overall number of entities is reduced. Thinking there would be a component for 5mm system holes, 8mm construction holes, etc, and an attribute for export DXF layer. For routing paths, I think a DXF Export Layer attribute should handle tool diameter, depth of cut, any cutter compensation, and lead in/outs, depending on the CAM post. So the plan is to create a script that writes a DXF for each face thats defined for machining and create any routing and/or drilling on that face.
                                  • Y Offline
                                    yvan
                                    It is not a problem. If you place the holes in a layer called a certain way ex: "DV_5" you can then set your CAM software to automatically use a 5mm bit to drill to the centre of any geometry placed in the layer "DV_5". no matter what shape the geometry is.
                                    For curved free form shapes, increasing the number of segments will produce an acceptable result.
                                      dedmin
                                      That is good news - I was wondering for a long time can this be a problem!
                                        Note that you can extract a DC's 'attributes' and use them in your 'reports'... there are several threads about this already... ๐Ÿ˜•
                                          dedmin
                                          Still, there isn't a clear solution for exporting DC options.
                                            Since an 'option' is itself an attribute can't you use that to 'filter' the other attributes as needed ?
                                            http://code.google.com/apis/sketchup/docs/tutorial_attrreporting.html
                                            • 1 / 3
