    ⚠️ Attention | Having issues with Sketchucation Tools 5? Report Here
    [Bug] NaN in a normal's value
    8 Posts 3 Posters 306 Views 3 Watching
      tomasz
      I have attached a skp file that contains a face that gives NaN in a normals at a vertex with index 2.
      Surprisingly SU doesn't find an error in the model.
      When such a normal is exported it can result in errors in a target application (i.e. rendering).
      When one selects the face and writes down following line will receive NaN for all three vector components.
      Sketchup.active_model.selection.first.mesh(7).normal_at(2)
      >>Vector3d(-1.#IND, -1.#IND, -1.#IND)
      I hope Google will make SU recognize such a face as degenerated.
      Corruption not recognized by SU FixProblems
      A face that is not being reported as faulty, but gives NaN in vertex normals
      Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
      • TIGT Online
        With your snippet I get Vector3d(-1.11463e-006, 1.65399e-006, -1) which is pretty near [0,0,1] and it does effectively face Z_AXIS.reverse ???
        For several mesh values I get
        Vector3d(0, 0, 0)
        Vector3d(0, 0, 0)
        Vector3d(0, 0, 0)
        Vector3d(0, 0, 0)
        at all the same for normal_at 1, 2, 3 etc
        I am puzzled ?
          tomasz
          Strange. Have you exploded the components?
          I am getting
          for the second vertex.
            tomasz
            I have tested it on SU Pro 7.1.6860 Win without a single plugin and it gives INT.
            Same in SU6 Free Win.
            Why our results are different?
              cjthompson
              That's weird. When I just put the face in edit mode, I get a result consistent with Tomasz's, but when I explode the 2 components, I get the same result as TIG.
              EDIT: I should also note that the face renders smoothed when I just put it in edit mode, but renders normally when I explode it.
                tomasz
                Do not explode the face. When exploded the wrong shading is gone and the problem all together.
                mesh=Sketchup.active_model.selection.first.mesh(7)
                1.upto(7) {|x| p mesh.normal_at(x)}
                Vector3d(-7.14257e-007, 1.60024e-006, -1)
                • TIGT Online
                  I exploded the inner component and got my 'good' result within the edit of the originally outer container...
                  If I don't explode at all and edit two levels deep, or I explode the outer container and edit what was the the inner one then I DO get the #INT error ??? Very strange - I suspect it's to do with trying to get the nested transformations?
                  Looking at the face itself you have managed to form a face with a double edged zero area inner 'loop' ??? If you select all and cut and paste in place it then reports a 'proper' vector again - even when it's still nested... Obviously some minor glitch in the database ???
                    tomasz
                    I have separated this face from a big file received from an user. I don't know how he managed to achieve it.
                    I will have to run a NaN check while exporting to prevent errors in an exported file.
                    It would be much better if SU could fix the face using 'ModelInfo\Statistics\FixProblems'.
