    Best inside SU renderer under $200
    extensions
    31 Posts 16 Posters 5.8k Views 16 Watching
    • MatteM Offline
      Matte
      Hi All,
      I have been trying to find out which are the best renderers under $200 ($100 would be even closer to what I can really afford) that work inside SU. I have dabbled with IDX Renditioner, IRender Nxt, Liteup, shaderlite(cant get it to work yet) to name a few, but was wondering from the few that have the opertunity to try them all what you think? In my attempts so far I seem to see the most promise was in the first two listed? Basically I'll be mostly doing interiors with a few lights added here and there for either artistic or "photorealistic" that don't look too "cartoon like". Thanks!
      Matte
        d12dozr
        Have you tried Twilight Render? That's probably your best bet, only $99 and can do everything you describe...and do it well I might add πŸ˜‰
        There is an active forum where you will get any question answered speedily, which is extremely helpful for a newbie. Check out the Showcase to see the quality of images Twilight can produce.
        http://goo.gl/f7ooYh
        • boofredlayB Offline
          boofredlay
          I will second Twilight.
          • N Offline
            notareal
            If it must be inside SU, then my pick would be twilight. For that you can use Kerkythea or even Thea Render as a studio, if your needs will grow.
            • jim smithJ Offline
              jim smith
              Don't forget Podium, works inside and is $179.00. the new version 2 coming out, now in free beta, seems to be quite an improvement. Pretty simple to use and I have found it to meet my needs. I have not seen or created many examples that someone will mistake for real time photographs, but it is good, specially for interiors.
              "Out of clutter find simplicity,
              from discord find harmony,
              In the middle of difficulty lies opportunity"
              Albert Einstein
                lapx
                ..and Kerkythea's free. No kidding. I like to know the reason why many are overlooking the free program unless they feel support will be lost. I'm sure you can get other features in the paid programs but Kerkthea can turn out some great professional renders with minimum post pro. You should look into it. Don't underestinate free.
                  bravoddb
                  Why don't you test a software like Thea render? Runs out of SU, but I found speed improvement and quality.
                  Is an Unbiased rendering software like Twilight, so these both for interiors are great,You can download the demo, and test all of them, and see what is good for you!! instead of think in a top price.
                  I have IRenderNxt, and also Podium, Twilight and Thea, I use IRenderNxt and/or Podium for some kind of clients, and when I have work as a freelance I use Twilight and/or Thea
                  And for exteriors Vue (e-on software)
                  I have some clients that they only want NPR renderings, so I use Piranesi.
                  All are very good, I have used all of them, always depends on the work, the client.
                  • MatteM Offline
                    Matte
                    Thank you all for your advice, I will slowly go thru and check out each of these options one at a time to see what works best. I'll use the same model with each option and see what each option creates.
                    Thanks Again,
                    Matte
                    • o2bwlnO Offline
                      o2bwln
                      I've been following this thread and am interested in any new developments/opinions from the OP?
                      Would love to hear what you ended up with.
                      Thanks,
                      O2bwln
                      • MatteM Offline
                        Matte
                        I will post the comparison images each renderer did as soon as Im done, along with seamed good and bad things about each one. But to let you know I am not looking for which type of renderer will do a perfect image after days and days of calculations. I'm looking for something more realistic, so I am doing quality at 5, 15, 30 min. and an hour. Im looking for something to add extra "feel" to the scenes with lights placed where needed. Ill also let you know what was good and bad about each type of light from the different packages. My present goal is to limit it to the two "best" and then look more under the hood of those two. Hopefully it will not take to much longer. Im having a problem reinstalling IDX renditioner at the moment. And there was one other I wanted to test. But the ones for Shaderlight, twilight, indigo, and podium are done already. I'll keep you posted.
                        • EdsonE Offline
                          Edson
                          one reason for that can be the fact it does not work inside sketchup. twilight seems to be their attempt to overcome this limitation.
                          I would emphatically recommend podium, especially if your focus is the project not the render. it's a one-click renderer and results are fantastic with very little effort.
                          http://www.mahfuz.arq.br
                          • FrederikF Offline
                            Frederik
                            Good point...
                            But I can see that Matte also have given Indigo a test and according to my knowledge, it doesn't run inside SU either... 😐
                            Somehow I find this a slightly odd way of putting things...
                            Unlike others, we've never tried to hide that the render engine behind Twilight is Kerkythea...
                            Emphatically... πŸ˜• Why...??
                            I understand it from your personal point of view, Edson, since we still haven't succeeded making a Mac OS platform of TWR, however, please also remember that it's the KT engine running behind all versions of Podium prior to v.2...
                            Cheers
                            Kim Frederik
                            • StinkieS Offline
                              Stinkie
                              He's not implying otherwise, Kim. All he's saying, is that KT doesn't run inside SU, and TW does. Which, of course, is true.
                              He knows. Like almost every SU user, including myself, out there knows. Why do we know? Because the Podium team never concealed the fact Podium 1 runs on KT. And because you keep telling us. Over and over. Which is okay, obviously. The bitchy attitude, however, isn't. So stop it, please. And don't give me "I don't know what you're talking about".
                              • EdsonE Offline
                                Edson
                                kim,
                                it is your right to find it odd but this is exactly what I am trying to say: twilight is KT inside sketchup and with much simpler operation. what is odd about this? it is even a kind of compliment to the KT guys who understood the limitations of what they were offering.
                                emphatically, yes a 1000 times because no other renderer has allowed me to concentrate on the architecture and come up with quite decent renders that are more than enough for me. I cannot say this much about any other app. and V2 (which, by the way, no longer uses the KT engine) is proving to be even better than v1.7.
                                no application or render plugin I know of produces the renders podium does with so little tweaking.
                                as for twilight, it does not exist for me as there is no mac version YET (how can this take so long!!!). I hear good things about it and have no problems recommending it to my students who have windows machines.
                                • FrederikF Offline
                                  Frederik
                                  Didn't mean to sound "bitchy" - but point taken... πŸ‘
                                  Perhaps I'm being nit-picking, but like I wrote, I find the wording "seems to be their attempt" a little odd...
                                  I don't see TWR as an "attempt"... I feel we've succeeded and have made a very good application...
                                  Furthermore I don't like the word "seems" in connection to the word "attempt"...
                                  I respect your personal preferences, but feel that your wording is very strong and in a somehow derogatory manner toward other render applications (not only TWR and KT)...
                                  Remember that you're a Global Moderator (equal with an ambassador) for the SCF...
                                  Yet there's a lot of mac users who are able to run TWR...
                                  Because you simply can't compile the code from Win to Mac...
                                  But it's being worked on... πŸ˜‰
                                  Cheers
                                  Kim Frederik
                                  • EdsonE Offline
                                    Edson
                                    dear kim,
                                    first of all, let me emphasize that this is meant as a friendly and respectful exchange of points of view. some people here may think we are starting one of those lengthy internet fights... we know better than that.
                                    I can only be tentative about this because I have not had the chance to test twilight. thus "seems" and "attempt". there is no demeaning intent in the use of these terms.
                                    I did not mean to be derogatory. I am merely stating the truth. I challenge anyone to prove what I am saying about podium wrong. if you can show me an application that is simpler to operate and produces the same results I will switch to it on the spot.
                                    all moderators here have their preferences and make them public very often. I have never been disrespectful to any application, plugin or member of the forum. although making my preferences public, I have recommended TW and KT many times before and will continue to do so as no app fits everyone.
                                    good for them. as for myself, I think virtualisation sucks for demanding applications. I am not going to be forced into windows just because some apps do not have a mac version. it means not only owning a licensed wmware copy (which I do) as well as windows and sketchup pro win (which I don't).
                                    that does not seem to be case with the developers of podium, idx renditioner, indigo, lightup, vray, artlantis, etc. they all managed to it.
                                    regards,
                                    • EdsonE Offline
                                      Edson
                                      Please remember that KT is available in native mac format - hence the reason why Podium has been available in mac format...
                                      However, it's not just the render engine that needs to be available for mac and according to my knowledge, it's the user interface in TWR that has proved to cause some headache...
                                      I'm sure this is about to get solved and you can try it yourself...
                                      yes. it seems that dealing with the UI is one of the challenges podium developers face.
                                      as I have stated before, I am eager to try TW. it is a good idea to have several options for different situations. for that reason I have acquired LightUp which I am about to start testing soon.
                                      • FrederikF Offline
                                        Frederik
                                        @edson said:
                                        ...some people here may think we are starting one of those lengthy internet fights... we know better than that.
                                        Absolutely...
                                        I didn't want to start such a fight...
                                        Besides... I acknowledge that each tool has it's place in the toolbox... πŸ˜‰
                                        (Podium is doing a good job with many models, TWR is needed for other projects, etc...)
                                        As you know very well, I'm not a programmer... πŸ’š
                                        Cheers
                                        Kim Frederik
                                        • StinkieS Offline
                                          Stinkie
                                          That we do. πŸ˜„
                                          True. I have quite a few renderers - including TW - and while I don't use all of them often, I quite like every last one. They all have their strengths.
                                          • MatteM Offline
                                            Matte
                                            Hi All,
                                            I dont know how to properly upload text and images, I am going to attempt to cut and paste from "word", I hope this works?
                                            Nope no luck? Does anyone have any advice on uploading a group of images with text notes? Make a PDF and Insert?
                                            Thanks Matte
