    [Plugin] Torus 1.0
    25 Posts 18 Posters 19.0k Views 18 Watching
      Regular Polygon
      Hi folks,
      I couldn't resist one more plugin for creating simple shapes. This is an easy to use plugin that draws a torus. You just go to the menu item Draw -> Torus, enter the parameters in a dialog box, and place the newly created component in the model. You could draw a torus with the SketchUp Follow Me Tool, but it would take 5 minutes instead of 5 seconds.
      Dialog box and torus.
      This plugin will also draw a "twisted torus". OK, I made up the name. But it is the shape you would get if you could cut the tube, twist the ends, and glue them back together. To see the twist, the tube needs to have a polygonal cross section. But, you can control this aspect of the geometry by specifying just a few latitude lines for the torus.
      Square tori twisted from 0-5 times.
      The examples above use a square torus. It is square because the tube has four latitude lines (the creased edges), with four sides (surfaces) in between, so the cross section is a square. The torus on the upper left has no twist. The next has one twist; if you follow one side around the torus, you will end up on the adjacent side after one revolution. The next torus has two twists, and so on, up to five twists.
      12 sided torus twisted 12 times.
      You can have any number of sides and twists. In the example above, the torus has 12 sides, and 12 twists, so each side reconnects with itself after one revolution.
      There is more documentation on the usage for this plugin, and a link to download it, here: regularpolygon.org/plugins/torus.php.
      My SketchUp Plugins
      • jason_marantoJ Offline
        jason_maranto
        I really dig all your plugins... but this one is unexpectedly cool.
        Best,
        Jason.
        • boofredlayB Offline
          boofredlay
          Cheers.
            d12dozr
            Sweet shapes, I would think geometry teachers would like this. πŸ€“
            RP, how about a fractal generating plugin? ...you know, just for kicks πŸ˜›
            http://goo.gl/f7ooYh
              shoeb_cars
              this plugin of yours is gonna make someone's life so damn easier.....i mean sketchup life.. πŸ˜›
              cheers bro
              • N Offline
                notareal
                πŸ‘ Sure, I can find a use for this. Thanks!
                • massimoM Offline
                  massimo Moderator
                  Thanks once again πŸ‘
                    meak
                    genius! big thanks
                      Geometric! 😎
                      Surface without edges πŸ’š
                      • BurkhardB Offline
                        Burkhard
                        I need 12 second for a round torus with dimensions but your twisted torus is genius πŸ‘
                        http://www.ia-plus.de
                          Ben Ritter
                          Thank you very much!
                            Regular Polygon
                            Thanks a lot everyone for all your positive feedback. πŸ˜„
                            That's an idea. I can't think of anymore simple shapes to draw. Definitely would be just for fun.
                            My SketchUp Plugins
                            • simon le bonS Offline
                              simon le bon
                              Hi Regular!
                              Are you going to join the happy few set list of the ruby masters ?
                              I didn't know today this plugin was existing. It is a new member : Arc who have told us about it regarding to an exercise we try to soluce.
                              Your Torus plugin make things too much easy (bad for the exercise πŸ˜‰ ). Thank you for sharing πŸ‘ πŸ‘ πŸ‘
                              make and endless spiral:
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EndlessBowl_010_th.jpg
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/EndlessBowl_011_th.jpg
                              +++simon
                              • BoxB Offline
                                It's a wonderful plug-in, ten minutes to whip up this.
                                http://i155.photobucket.com/albums/s296/storeben/SU/Speed28003.gif
                                  Regular Polygon
                                  What a coincidence that our separate lines of work would meet like that! 😲
                                  You are doing things I never imagined people would do with this plugin. πŸ‘
                                  My SketchUp Plugins
                                    Regular Polygon
                                    Thanks Box -- I really like your new avatar. πŸ‘
                                    My SketchUp Plugins
                                    • BoxB Offline
                                      That is thanks to you, it's one of your Toruses/Tori/torum. πŸ˜’
                                      • H Offline
                                        halim
                                        can anyone make setting for this examples
                                          Regular Polygon
                                          Hi halim,
                                          The top torus with 20 twists had these settings:
                                          The bottom six tori had these settings, except they each have a different twist parameter varying from 0-5.
                                          P.S. Welcome to the forum!
                                          My SketchUp Plugins
                                            putnik
                                            Thanks a bunch Regular Polygon! 3 twists setting produces geometry of the winning entry for Astana National Library by Bjarke Ingles Group (http://www.big.dk) 😲
                                            http://www.google.com.au/images?hl=en&source=imghp&q=Astana+National+Library&btnG=Search+Images&gbv=2&aq=f&aqi=&aql=&oq=&gs_rfai=
                                            http://keshas.info
