    Please help!! Follow me prob.
    5 Posts 3 Posters 247 Views 3 Watching
      chucky
      Hi all,
      Has anyone had this before; when iI do a 'follow me', all the edges of the profile are not drawn. See attached.
      Thanks for a great forum.
      • TIGT Online
        Try it with the face in a different relationship to the path...
          chucky
          Hi TIG,
          Thanks for the response. Not quite sure what you mean when you say 'different relationship'. I've tried putting the profile inside & outside the path, but I'm still getting the same results. ( changed the profile a bit to suit final gutter design).
          File attached.
          follow me.skp
          • Jean LemireJ Offline
            Jean Lemire
            Hi Chucky, hi folks.
            Maybe your path is not correct or the profile is not touching it correctly.
            See this SU file for ideas.
            follow me.skp
              chucky
              Thanks Jean,
              Still touch & go, but seems to be working now. I had to experiment with placing the profile on different points along the path to get a perfect 'followme'.
              Thanks to all,
