    Acoutical tile ceiling in sketchup
    6 Posts 4 Posters 2.7k Views 4 Watching
    • E Offline
      eccowboy
      Can someone tell me how to show the above ceiling in my model. I know how to draw a typical ceiling,
      but I would like to show an armstrong type of ceiling. I know that you can draw it in photo shop, non user
      but is there a way that I can show it directly in my model. I do use the 3D warehouse, but it's a real bugger
      to import, draw etc.
        Can you add the image... πŸ˜•
        • W Offline
          watkins
          I think he is talking about a suspended ceiling
          Page Not Found : 404
          (www.armstrong.com)
          Regards,
          Bob
            This is a relatively easy thing to do πŸ˜•
            You model a simplified version of it using 600x600 sq tile componnetss, copied in x & y the number of times needed or whatever and some slight PushPulling around the compo's edges to form a 'T-bar' etc. Work in a group to separate geometry.
            You need to make-unique some edge tiles to suit 'cuts' and swap them out...
            Here are some steps... Capture.PNG This shows a simple tile component with a 'half' T-grid with hidden edges so it 'mates with its neighbors...
            Capture1.PNG Here it is copied in x & y 6m and 3m - note how the T-bars melt together... Capture2.PNG
            But the room isn't 6m long, it's 5.8m... Capture3.PNG so the last tile is made unique and renamed as 400 wide 'cut' and one side of tile moved over by 200mm [if you want 'even margins' move the whole ceilinng another 100mm over, and make the cut tile 500 and use it on BOTH ends...]
            Capture4.PNG swap the edge tiles for the 400 cut version [note this image shows hidden geometry so that you can see the hidden T-bar joins]...
              pmiller
              You can also make the topside surfaces transparent -- allows you to look from above through the grid and eliminates ceiling shadow.
              • E Offline
                eccowboy
                Thanks, everyone for your reply. One more question I'm new in Piranesi, do any of you know
                how to set up a drawing, the book I have isn't that great. Especially when I want
                to insert people, objects. Sometime they scale up and down and other times they don't.
                Plus the book always works in meters.
