    I am Finally BUILDING!!!
    101 Posts 23 Posters 19.4k Views 23 Watching
    • K
      KXI System
      Glad you making progress.
      Getting the perfect sig is hard...
      Google it!
      • david_hD
        david_h
        backfilling the foundation right now. floor slabs tomorrow. Framing next week.
        • david_hD
          david_h
          more pix. .. just cuz I like posting them and I am so excited!
          A little film. I still can't figure out the embed thing
            Nice Pool πŸ˜‰
            • Chris FullmerC
              I was thinking its a great start for a bomb shelter.
              • david_hD
                david_h
                what. . .you guys don't have full basements where you live.
                Tant pis. It's cheap space. πŸ˜‰
                • Chris FullmerC
                  I'm not sure that I've ever really seen a full basement in California. I'm not sure why.
                  • T
                    tim
                    Partly a side effect of frostline depth. In the Frozen North like Minnesota the frostline depth is, oh, about 350ft down - in California it's about 18" above ground πŸ˜„ . Since you need to have the base of your footings below frost depth to avoid frost heave ruining your building you inevitably get a high likelihood of basements in Minnesota and a low probability in California.
                    I'm building on a slope, so it made sense to do a walk-out basement, also known as a lower floor with a dirt back wall.
                    • Chris FullmerC
                      Interesting, I did not realize that building footings needed to be below the frost line. That would help explain things a bit.
                      • ely862meE
                        ely862me
                        Makes me wonder: No insulation on the exterior?
                        Elisei (sketchupper)
                        Come and See EliseiDesign
                        • aadbuildA
                          aadbuild
                          Hi David, If you need any building actual advice flick me over an email. I design and build. mainly build. BTW thw house model looks great
                          Every building designed can be affordable & buildable, to help we built PlusSpec; VDC & BIM for Sketchup
                          https://www.plusspec.com
                          • david_hD
                            david_h
                            ELY::The Interior furred walls will be insulated. In the Mountain areas, like Park City for example you would do 2" of Rigid on the outside of the foundation, then do the bituthane thing. And still furr and insulate the interior foundation wall.
                            But where I am at, I should be fine. Frost depth for my elevation. . .32"
                            AAD: thanks for the offers to advise. I think I got it covered. Although I can see mistakes that I have made along the way.
                            Garage Slab poured this weekend! My wife says. . .the garage is too small. Honey. .it's bigger than we have ever had before. It just looks small because the walls aren't on it yet. Nothing to compare it too. Trust the SketchUP model. The cars fit!!!!
                            • david_hD
                              david_h
                              basement rooms bearing walls and main floor getting framed. 😍
                              • ely862meE
                                ely862me
                                I see,the earth is different in all the countries(and the weather too) .Here(in Romania) if u go that deep with the basement and no insulation on the outside u ll have wall mold all the way.
                                πŸ˜†
                                So u re going wood all the way? I personally don t trust wood. Give me bricks and concrete. πŸ˜„
                                Btw,things are going pretty well!
                                Cheers!
                                • daleD
                                  dale
                                  Hey David
                                  It's great to see a follow through from SketchUp to build. I'm hoping to follow your lead in the next little while. Makes me want to through on the tools and dive in. Keep us posted on progress.
                                  • david_hD
                                    david_h
                                    We've been building frame houses here for many many years. Its lightweight strong and I can afford it. πŸ’š
                                    D
                                      You mention SU output David, but are you willing to give us a sneek peek at what your home will look like?
                                      Or maybe you have somewhere else?
                                      • W
                                        watkins
                                        Dear David,
                                        What are you going to do about sound insulation?
                                        Server Maintenance
                                        (www.bre.co.uk)
                                        Kind regards,
                                        Bob
                                        • david_hD
                                          david_h
                                          check out the first of the post to see the idea. Here's a new quickie render based on a few tweaks. I havent' really done anything with Landscape yet, so that's not worked out as you see in the render.
                                          as far as sound insulation goes. . .batt insulation throughout for sound and weather. It's required. As far as noise goes, I don't care about me bothering my neighbors with a huge big-A flat screen with surround sound. . .i just don't want them bothering me.
                                          Jus Kiddin'!!! πŸ˜†
                                          • david_hD
                                            david_h
                                            another quickie render. .. no detail yet, but this was to show my wife the ideas for the kitchen and family room. The materials for the most part are just place holders until we make our selections, but my wife . . .even with all the sketchupping in the world, didn't get a sense of the scale. Geez. . .she's like every other client I have ever had!
                                            • 2 / 6
