    NO DWG IN SKETCHUP
    6 Posts 6 Posters 786 Views 6 Watching
      alen
      HELLO
      I GOT A BIG PROJECT AND TRYING OPEN AN AUTOCAD DWG FILE INTO SKETCHUP PRO
      AND CAN NOT. WHEN I AM IN SKETCHUP AND OPENING FILE TYPE ,DWG AUTOCAD FILES DO NOT EXIST .
      PLS HELP
      OFECS@WINDOWSLIVE.COM
      • daleD
        dale
        In SU 7, the dwg import option is only in the pro version.
        • K
          Khai
          http://sketchup.google.com/support/bin/answer.py?answer=161784
          here's the DWG importer for Sketchup 7.1 free, Enjoy.
          • BoxB
            He says he has pro, I think the problem is you don't open it, you Import it.
            Go File/Import and you will find it there.
            • bmikeB
              bmike
              YOU SHOULD TALK IN ALL CAPS ALL THE TIME!
              Look for the pull down. If using Pro, you should be able to open DWG.
              • E
                eccowboy
                When I first started using sketchup I was working in ADT, I found that I couldn't import that type of drawing into
                sketchup, but I did find out if I worked in the standard autocad, i.e. say release 2004 it would important
                and I had no problems after that.
