π Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
What type of plants should I use?
I have a quick question for all:
If I doing VRAY render, what type of plants you recommended, 3D low poly?....2D PNG plants?... Any web so I can look at?...
Thanks in advance...
Both. It really depends on the scene. Far distance you can often get away with 2D billboards, mid-distance low poly 3d, and for close up you'd most likely need high poly 3d. It's all about scale - distance from camera and how much detail you see.
Or, you could add it in post.
As far as 2D plants go, these are great: http://www.cadplants.com/
