    Retrieve Color Layer assigned by Sketchup
    16 Posts 4 Posters 2.1k Views 4 Watching
    • C
      c.plassais
      Hello everyone,
      Is there a method to retrieve the color assigned by Sketchup to each layer ?
        Not via the Ruby API - think it might be possible using the SDK.
        • Dan RathbunD
          Dan Rathbun
          Not in the current API, sorry.
          The other half of your "wish" (being able to set the color,) has already been requested in the API Wishlist forum.
          ie: http://forums.sketchucation.com/viewtopic.php?f=180&t=13666&p=165527&hilit=Layer#p165527
          That wishlist topic was created by Scott from Google, so it's the place to have your 'wishes' be known to the GSU Team. (I encourage you to post your wish for the "attribute getter" side of the Layer color issue.)
          I'm not here much anymore.
          • C
            c.plassais
            Thank you to you for informations
            Damage
            I look at
              I wrote the layer.color=() .rb [do a search] that let's you set a layer's color using Ruby.
              Also getting a the layers' colors would be possible by exporting a temporary DXF and then getting the colors from that BUT there's nothing available direct from the API 😞
              • C
                c.plassais
                thank you TIG
                I downloaded your plugin and I looked
                It's for my little plugin ➑ http://forums.sketchucation.com/viewtopic.php?f=323&t=28957#p251619
                I try to add a tool to draw lines with the color of the active layer
                Probably the best solution is with the API SDK C + +, as indicated Thomthom.
                I found in SDK, this method
                OLE_COLOR ISkpLayer::Color [get] Returns the color associated with this layer.
                but it is too complicated, Ruby and English is already a lot of work for me πŸ˜†
                  @dan rathbun said:
                  I found [url][Plugin] List Layer Colors.rb[/url] (the topic title is a bit mis-spelled BTW.)
                  It creates a CSV file of Layers and their Colors. But I don't see it setting colors.
                  [Any further comments on the above plugin, I'll post in that topic.]
                  EDIT [ Maybe I missed the plugin you were refering to? ]
                  Nevermind.. I found it, it is a [Code] not a [Plugin].
                  It's here: [Code] layer-color= v1.2...
                  That's my code to 'set' a layer's color - it does NOT 'get' it - hence the layer.color**=** method.
                  There are several ways of using it layer.color="red" etc. It is terribly clunky, only works for colors [not textures] and would be much better as a built-in method...
                  There was talk of another layer.material method to get the layer's material [I recall it was AdamB's ?] but it hasn't arrived as far as I know... http://forums.sketchucation.com/viewtopic.php?f=180&t=25697&p=224534&hilit=layer#p224534
                  • C
                    c.plassais
                    Thank you Dan
                    For your help and your time
                    even a csv list of color layers, it's good for me
                    • C
                      c.plassais
                      and thank also TIG
                      for your plugin and your time πŸ‘
                      I use only color, no materials
                      layer.color one method is perfect for me
                      Not to change the color layer, just retrieve and use
                        This is the 'layer color' csv listing tool http://forums.sketchucation.com/viewtopic.php?p=11924#p11924
                        It needs Pro though... πŸ˜•
                        • Dan RathbunD
                          Dan Rathbun
                          I found [Plugin] List Layer Colors.rb (the topic title is a bit mis-spelled BTW.)
                          Jim's new indexes are great!!
                          • Dan RathbunD
                            Dan Rathbun
                            Woops! Messed up the url... updated my previous post.
                            • C
                              c.plassais
                              ListLayerColors is perfect for me
                              must be an object layer to export the layer color
                              Thx TIG
                              Is it possible to use it in my plugin ?
                                Thx TIG
                                A layer needs to have been used [i.e. have at least one face on it] to export as an OBJ and thereby get the color listed, BUT you could simply make a grouped triangular face and give that face a layer - iterate through the model.layers adding the grouped faces until all layers are all done, then run your version of the tool and you have ALL layer colors including unused ones listed in the csv...
                                You can keep a tally of the temporary face-groups as you make them and then erase them as the OBJ export completes...
                                Feel free to use my code as you like: a brief mention of my original code/ideas would be kind; if you are to use it commercially then a small donation would be even kinder [if so, PM me about that]... πŸ€“
                                • C
                                  c.plassais
                                  TIG,
                                  I understand the tip to export all layers
                                  My plugin is not commercial, freeware only on SCF and my French forum
                                  A thousand times thank you πŸ‘
                                  • C
                                    c.plassais
                                    Hy,
                                    TIG plugin ListLayerColors after some modifications, can create new colors in the pallet with layer's colors
                                    require 'sketchup.rb'
                                    class CreateLayerColors
                                    def CreateLayerColors ;;get()
                                      model=Sketchup.active_model
                                      entities = model.active_entities
                                      materials=model.materials
                                      layers=model.layers
                                      if model.rendering_options["DisplayColorByLayer"]==false
                                        model.rendering_options["DisplayColorByLayer"]=true
                                    	already_on=false
                                      else
                                        already_on=true
                                      end#if
                                      # create temporary entities for exporting layers
                                      vecteur = Geom;;Vector3d.new 0,0,1
                                      centre = Geom;;Point3d.new 0,0,0
                                      group_temp=entities.add_group()
                                      entities = group_temp.entities
                                      x =0
                                      layers.each {|layer|
                                      model.active_layer = layer
                                      centre = [centre[0], centre[1], centre[2] + x]
                                      edges = entities.add_circle centre, vecteur, 0.01
                                      cercle = entities.add_face(edges)
                                      x= x + 0.01
                                      model.save "temp"
                                      mpath = Sketchup.find_support_file "temp", "Plugins/"
                                      model.export(mpath +".obj",false)
                                      mtl=mpath+".mtl"
                                      text=IO.readlines(mtl)
                                     0.upto(text.length-1) do |i|
                                      if text[i]=~/^newmtl */
                                        name=text[i].slice(7..-2)### layer name only
                                        rgbR=((text[i+2].slice(3..11).to_f)*255).to_i.to_s### color rgb values
                                        rgbG=((text[i+2].slice(12..20).to_f)*255).to_i.to_s### color rgb values
                                        rgbB=((text[i+2].slice(21..29).to_f)*255).to_i.to_s### color rgb values
                                      	couleur_calque = Sketchup;;Color.new(rgbR.to_i, rgbG.to_i, rgbB.to_i)
                                            unless materials[name]
                                    	    new_matiere = materials.add name
                                    	    new_matiere.color = couleur_calque
                                    	    new_matiere = new_matiere.name
                                    	else
                                    	    materials[name].color = couleur_calque
                                      end#if
                                     end#upto
                                      File.delete(mpath+".obj")
                                      File.delete(mtl)
                                      File.delete(mpath)
                                      group_temp.erase!
                                      model.rendering_options["DisplayColorByLayer"]=false if already_on==false
                                    end#def
                                    end#class
                                    ### menu
                                    # add menu items
                                    if(not file_loaded?("CreateLayerColors.rb"))
                                      UI.menu("Plugins").add_item("Create Layer Colors"){CreateLayerColors;;get}
                                    end#if
                                    file_loaded("CreateLayerColors.rb")
                                    CreateColorLayer
                                    Christophe
