    Retrieve Color Layer assigned by Sketchup
    16 Posts 4 Posters 2.1k Views 4 Watching
      @dan rathbun said:
      I found [url][Plugin] List Layer Colors.rb[/url] (the topic title is a bit mis-spelled BTW.)
      It creates a CSV file of Layers and their Colors. But I don't see it setting colors.
      [Any further comments on the above plugin, I'll post in that topic.]
      EDIT [ Maybe I missed the plugin you were refering to? ]
      Nevermind.. I found it, it is a [Code] not a [Plugin].
      It's here: [Code] layer-color= v1.2...
      That's my code to 'set' a layer's color - it does NOT 'get' it - hence the layer.color**=** method.
      There are several ways of using it layer.color="red" etc. It is terribly clunky, only works for colors [not textures] and would be much better as a built-in method...
      There was talk of another layer.material method to get the layer's material [I recall it was AdamB's ?] but it hasn't arrived as far as I know... http://forums.sketchucation.com/viewtopic.php?f=180&t=25697&p=224534&hilit=layer#p224534
      • C
        c.plassais
        Thank you Dan
        For your help and your time
        even a csv list of color layers, it's good for me
        • C
          c.plassais
          and thank also TIG
          for your plugin and your time πŸ‘
          I use only color, no materials
          layer.color one method is perfect for me
          Not to change the color layer, just retrieve and use
            This is the 'layer color' csv listing tool http://forums.sketchucation.com/viewtopic.php?p=11924#p11924
            It needs Pro though... πŸ˜•
            • Dan RathbunD
              Dan Rathbun
              I found [Plugin] List Layer Colors.rb (the topic title is a bit mis-spelled BTW.)
              Jim's new indexes are great!!
              I'm not here much anymore.
              • Dan RathbunD
                Dan Rathbun
                Woops! Messed up the url... updated my previous post.
                • C
                  c.plassais
                  ListLayerColors is perfect for me
                  must be an object layer to export the layer color
                  Thx TIG
                  Is it possible to use it in my plugin ?
                    Thx TIG
                    A layer needs to have been used [i.e. have at least one face on it] to export as an OBJ and thereby get the color listed, BUT you could simply make a grouped triangular face and give that face a layer - iterate through the model.layers adding the grouped faces until all layers are all done, then run your version of the tool and you have ALL layer colors including unused ones listed in the csv...
                    You can keep a tally of the temporary face-groups as you make them and then erase them as the OBJ export completes...
                    Feel free to use my code as you like: a brief mention of my original code/ideas would be kind; if you are to use it commercially then a small donation would be even kinder [if so, PM me about that]... πŸ€“
                    • C
                      c.plassais
                      TIG,
                      I understand the tip to export all layers
                      My plugin is not commercial, freeware only on SCF and my French forum
                      A thousand times thank you πŸ‘
                      • C
                        c.plassais
                        Hy,
                        TIG plugin ListLayerColors after some modifications, can create new colors in the pallet with layer's colors
                        require 'sketchup.rb'
                        class CreateLayerColors
                        def CreateLayerColors ;;get()
                          model=Sketchup.active_model
                          entities = model.active_entities
                          materials=model.materials
                          layers=model.layers
                          if model.rendering_options["DisplayColorByLayer"]==false
                            model.rendering_options["DisplayColorByLayer"]=true
                        	already_on=false
                          else
                            already_on=true
                          end#if
                          # create temporary entities for exporting layers
                          vecteur = Geom;;Vector3d.new 0,0,1
                          centre = Geom;;Point3d.new 0,0,0
                          group_temp=entities.add_group()
                          entities = group_temp.entities
                          x =0
                          layers.each {|layer|
                          model.active_layer = layer
                          centre = [centre[0], centre[1], centre[2] + x]
                          edges = entities.add_circle centre, vecteur, 0.01
                          cercle = entities.add_face(edges)
                          x= x + 0.01
                          model.save "temp"
                          mpath = Sketchup.find_support_file "temp", "Plugins/"
                          model.export(mpath +".obj",false)
                          mtl=mpath+".mtl"
                          text=IO.readlines(mtl)
                         0.upto(text.length-1) do |i|
                          if text[i]=~/^newmtl */
                            name=text[i].slice(7..-2)### layer name only
                            rgbR=((text[i+2].slice(3..11).to_f)*255).to_i.to_s### color rgb values
                            rgbG=((text[i+2].slice(12..20).to_f)*255).to_i.to_s### color rgb values
                            rgbB=((text[i+2].slice(21..29).to_f)*255).to_i.to_s### color rgb values
                          	couleur_calque = Sketchup;;Color.new(rgbR.to_i, rgbG.to_i, rgbB.to_i)
                                unless materials[name]
                        	    new_matiere = materials.add name
                        	    new_matiere.color = couleur_calque
                        	    new_matiere = new_matiere.name
                        	else
                        	    materials[name].color = couleur_calque
                          end#if
                         end#upto
                          File.delete(mpath+".obj")
                          File.delete(mtl)
                          File.delete(mpath)
                          group_temp.erase!
                          model.rendering_options["DisplayColorByLayer"]=false if already_on==false
                        end#def
                        end#class
                        ### menu
                        # add menu items
                        if(not file_loaded?("CreateLayerColors.rb"))
                          UI.menu("Plugins").add_item("Create Layer Colors"){CreateLayerColors;;get}
                        end#if
                        file_loaded("CreateLayerColors.rb")
                        CreateColorLayer
                        Christophe
